XR11/73
garry55
Re: XR11/73
Post by garry55 »
tz375 wrote: and the fact that the barrels are not on the centerline and in a GT the right barrel hangs out more than the left side. If the motor is centralized it may complicate wheel and chain alignment.
I hadn't realised this was a standard feature of the GT - but with my motor centralised in the GK73A frame I have noticed that the drive sprocket is out-of-line, requiring the motor to be moved to the right. I have room to slide the motor across to either side, so I guess final positioning will be determined by chain alignment. And I won't feel that I've done it wrong if thats how Suzuki intended it!
Thanks for that nugget :clap:
Garry
garry55
Re: XR11/73
Post by garry55 »
Suzukidave wrote:
garry55 wrote: is that your SRAD / Kettle Dave ?
Yes
I cant see a radiator :lol:
Looks a very neat installation - think I am going to relent and read your build thread - you have the link please?
Garry
Re: XR11/73
garry55 wrote:I cant see a radiator :lol:
I doubt that you can do it with the frame you are using, but I always thought this look - having the radiator behind the engine - looked really nice. This was done by a fellow in Norway. I suspect there is a cooling fan buried in there somewhere - but maybe not. The other nice touch was incorporating the oil tank (see the level glass at the back left corner), and the temp and speedo into the fuel tank. Very clean.
Re: XR11/73
garry55 wrote: I cant see a radiator :lol:
I used a top radiator off a Suzuki TL1000R as it was all i could find to fit the space below the neck and above the pipes . The build thread got lost when the Sundial site was redone several years ago . :cry: Image
Re: XR11/73
It worked in my favor having to center the cylinder block in the frame as this moved the front sprocket to the left .. this and the longer shaft of the GS750 transmission made the line up to the 6" wide rim and 170 tire perfect .
Re: XR11/73
If you think of the 750 as a GT500 with the third cylinder stuck on the right outside of the primary drive, it makes sense that the right pot is right of center. Of course that makes it more of a challenge to fit that motor into a symmetrical perimeter frame without driveline issues. The fact that the motor in a modern frame is therefore pushed to the left may make it easier to match up to wide wheels without adding shaft extensions or huge sprocket offsets, so maybe it's not all bad. If the sprockets don't line up, just fit a wider wheel. :roll:
garry55
Re: XR11/73
Post by garry55 »
Yes Ian - I do like the clean look of the engine in that bike - on radiator positioning I have 3 trains of thought:-
1 small rad to the front like on Dave's SRAD/GT (the standard GSXR400 rad I have is way too big - grrrrrr!)
2 under-seat with cold-air ducting from the fairing. And possibly a fan (or 2).
3 in a "V" under the motor - like a belly pan. My mate runs this system successfully on his race bike.
Garry
garry55
Re: XR11/73
Post by garry55 »
Suzukidave wrote: I used a top radiator off a Suzuki TL1000R as it was all i could find to fit the space below the neck and above the pipes . The build thread got lost when the Sundial site was redone several years ago . :cry:
Thats an option Dave - thanks for the info. Real shame about the loss of the thread - was looking forward to reading it at work tonight!
Garry
garry55
Re: XR11/73
Post by garry55 »
Suzukidave wrote:It worked in my favor having to center the cylinder block in the frame as this moved the front sprocket to the left .. this and the longer shaft of the GS750 transmission made the line up to the 6" wide rim and 170 tire perfect .
It works against me Dave, as the 400 runs a narrow wheel / tyre combo and with the motor centralised in the frame, the drive sprocket actually sits outside the frame !
Looks like a lop-sided motor is the solution.
Garry
Re: XR11/73
Won't a lopsided engine cause balance problems?
You may have to extend the sprocket outwards so to speak.
Maybe machine the sprocket centre out and extend it with a tube with an outrigger bearing to carry the new sprocket position.
Don't want you to build a bike that will only go in circles mate!
I'm an engineer who sees engineering problems and hopefully, solutions to them!
garry55
Re: XR11/73
Post by garry55 »
As long as it pulls to the right, Alan, it'll be fine for Cadwell :D
Garry
Re: XR11/73
Alan H wrote:Won't a lopsided engine cause balance problems?
I think you read that wrong Alan , his engine has the output sprocket already too far out , Garry says he needs to move the engine to the right to get things to line up but that will have the engine sticking way out the right side of the frame ??
garry55
Re: XR11/73
Post by garry55 »
I'm a bit confused here - according to tz375's earlier post, the motor hangs further to the right - or am I reading this wrong? Can anyone confirm where the centre-line of the motor is, relative to the cylinder head / crankcases?
My drive sprocket may just be that far out as I can't accurately mate the frame and motor yet so rely on "resting" the frame on the head. And it will keep sliding off. Once I can fix the motor via the new upper rear mounts, I will get a clearer picture.
And take one for you to peruse...........
Garry
Re: XR11/73
With a stock GT the engine does sit with the cylinder off set to the right , Suzuki balanced the look of the engine with the alt. and points sticking out a equal amount . I was thinking around your post that with the cylinder centered in the new frame the output sprocket sits out side the frame . So my thinking was you would have to move the whole engine off to the right to line up the sprockets .. just a guess would maybe be 1~2" ?
Re: XR11/73
Quite possibly. I could be mixing the bikes up in the thread or looking from the front instead of the back. It's an age thing, I'll just have to paint an arrow on my bike seat so I always face forward when I get on. :wink: .
