XR11/73
Re: XR11/73
A lot goes into custom modding :shock: its all those details :|
garry55
Re: XR11/73
Post by garry55 »
isn't it just................
I've been putting these jobs off for a while now, but as I am all worked-up on my current projects, I took the time to knock them off the "to-do" list.
Garry
garry55
Re: XR11/73
Post by garry55 »
plugging the water passages with an old water pump body..............
using a nut and bolt and an "o" ring to prevent seepage................
pump body refitted and silicone injected into passage to thermostat housing.........
Garry
garry55
Re: XR11/73
Post by garry55 »
then out with the hacksaw and an old, damaged timing side casing............
and some time later........................
another 3" taken off the engine width.............
and a little bit added back on..................
but carbon fibre weighs a lot less than a block of alloy............. :up:
Garry
garry55
Re: XR11/73
Post by garry55 »
not a lot today - plugged the oil galleries that feed the l/h side (where the water pump/ tacho drive gears live) using a metal putty applied from both sides.
from the outside................
and inside....................
also dispatched a spare clutch cover to a company that specialises in water-jet cutting of aluminium to have what amounts to a "full" gasket produced out of 4mm sheet. Saves me from having to do a a lot more drilling / shaping / filing :up:
Garry
sportston
Country: England, UK
Re: XR11/73
Post by sportston »
garry55 wrote:not a lot today - plugged the oil galleries that feed the l/h side (where the water pump/ tacho drive gears live) using a metal putty applied from both sides.
Ah the good old racing chewing gum trick! I wonder how many races have been fought and won thanks to a bit of putty....
Do you think it will hold permanently?
Re: XR11/73
Define "Permanently" in the context of an old two stroke triple. :? :lol:
garry55
Re: XR11/73
Post by garry55 »
sportston wrote: Do you think it will hold permanently?
I have no idea - just hoping, really............ :D
Garry
garry55
Re: XR11/73
Post by garry55 »
tz375 wrote:Define "Permanently" in the context of an old two stroke triple. :? :lol:
:up: :D :up: :D
Garry
garry55
Re: XR11/73
Post by garry55 »
look what arrived today....................
...................the clutch housing :up: :D
Garry
garry55
Re: XR11/73
Post by garry55 »
the water-jet cut clutch side casing in place............
Garry
garry55
Re: XR11/73
Post by garry55 »
Garry
garry55
Re: XR11/73
Post by garry55 »
final shaping of clutch aperture, as was last night..............
as is tonight.................
fed up of filing, me............
Garry
garry55
Re: XR11/73
Post by garry55 »
collected the GS input shaft and the modified clutch hub today...........
and remembered to remove the roll pins from the shaft bearings (GS gearboxes use half-ring retainers and roll pins - GT750's only use half-rings)...........
also cut the hole in the side plate for the kick start shaft...........
input shaft, clutch hub and kick start shaft in place........
Garry
garry55
Re: XR11/73
Post by garry55 »
tonight I have been mostly modifying the clutch pressure plate to accept a small, sealed roller bearing....
.........the purpose of which is to allow the pressure plate to rotate freely around the clutch pull shaft......
ooops! - the pressure plate doesn't fit inside the aperture ..........
did I mention previously about the final shaping of the clutch aperture? A tad prematurely, as it happens..............
more bloody filing.........but the result is worth the effort.........
Garry
