XR11/73
- garry55
Re: XR11/73
no need - I rely on you to keep me on my toes!
You've been there, done that and got the tee
Garry
- Suzuki 2-Strokes: GT550L, PE250B, RM250N
Re: XR11/73
What sort of self-generating ignition system are you going to be using??garry55 wrote:no need for that Dave - I've decided to run the standard water pump now so, along with the self-generating ignition system and a self-contained battery powered tachometer and water temp gauge, a 12v on board battery isn't needed.Suzukidave wrote:I guess you could put a small battery charger on the bike somewhere and every time you park plug it in
Unless I've overlooked something.........
- garry55
Re: XR11/73
I am using a HPI system - I've opted for the one that fits on the r/h side of the motor. Just hoping that the ignition rotor relies on the crank taper to remain in place and doesn't need a keyway. I have asked this question to HPI and am awaiting a reply
Garry
Re: XR11/73
Wow those HPI systems look really good. Seems they have a large number of upgrades/options to really trick out your ignition tune. Wish I could get one for my 550. Are you going the analogue or digital version??garry55 wrote:I am using a HPI system - I've opted for the one that fits on the r/h side of the motor. Just hoping that the ignition rotor relies on the crank taper to remain in place and doesn't need a keyway. I have asked this question to HPI and am awaiting a reply
- garry55
Re: XR11/73
HPI do list an ignition for the 550
I think it's digital
Garry
- garry55
Re: XR11/73
Chopper forks will sort it.
- garry55
Re: XR11/73
Raleigh Chopper forks?
Garry
Re: XR11/73
You mean like this? Braking might be an issue, but the mod would be straightforward (see second pic).
Re: XR11/73
All the pics I've seen seem to have two cylinder engines mounted front/back direction, so it might not work with a triple.
You might like to comment as the pics show lighter bikes with 'space frames'.
Handling 'might' be affected, but the pedals would be OK as you don't appear to have any method of starting the engine on yours.
Re: XR11/73
Put the poor thing out of it's misery FFS.
- garry55
Re: XR11/73
in readiness for the 17" rear wheel transplant, I set about measuring the standard ride height with the 18" GSXR wheel in situ using a piece of strip plastic
out with Gixxer wheel, in with the Aprilia RS250 wheel and Brembo caliper
not sure if you can see the "bend" in the plastic strip, but I'll make some new, shorter dog bones at work on Monday to restore the ride height to standard.
front wheel to fit tomorrow........
Garry
- Country: us
- Suzuki 2-Strokes: 73 gt 750 74 gt550
Re: XR11/73
nice work man. really nice
