Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Mon Jul 06, 2020 2:16 pm
Post new topic Reply to topic  [ 373 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25  Next
Author Message
PostPosted: Sun Aug 20, 2017 8:36 am
Offline
Kevin does have a engine tuner so i dont know how much of what goes on inside the motor he can talk about :ssh:
_________________
Top
 Profile
PostPosted: Sun Aug 20, 2017 9:51 am
Offline
Twas ever thus with engine tuners :D
Top
 Profile
PostPosted: Tue Oct 03, 2017 10:03 am
Offline
Ready for our first and last meeting this year with the CRMC 500 Air Cooled class at Brands Hatch this weekend. We also have an entry for the open King of Brands race on the Sunday. We have the luxury of pit garage #7 which we are sharing with a couple of the other lads, stick your head around the door and say hello if you are passing.
Top
 Profile
PostPosted: Tue Oct 03, 2017 2:38 pm
Offline
Suzuki 2-Strokes: GT750 hybrids (x2) VJ23A RGV500 TS185 R250
Good luck :up:
Hope all goes well.
_________________
Garry
I'm addicted to brake fluid, but I can stop anytime.
Top
 Profile
PostPosted: Sat Nov 04, 2017 7:52 pm
Offline
The races at Brands Hatch were curtailed both days because of incidents and we did not get all our scheduled races even started. Still, on the Friday test day Gary May stuck in a couple laps in the 55s , the best being 55.52s which is almost a second under the our class lap record. We did complete one 500 Air Cooled race where Gary came from row 13 on the grid to place 2nd. Here he is at Paddock Hill bend:
The bike has since been stripped for a winter tart up. The frame is now away getting painted (metallic grey)
Anyone for a T500 race engine :D
Cheers Geoff
Top
 Profile
PostPosted: Sun Nov 05, 2017 5:32 am
Offline
Country: Switzerland
Suzuki 2-Strokes: T500 Suzuki, AJR Bultaco, Honda NS475
Hi Geoff
Nice to read you got the bike out for Brands and seems Gary was really flying, was that the race engine? Looks like you have quite some work on over the winter. I did only 2 race meetings this year because of work commitments, so was not able to defend or improve my 3rd place in the 2016 championship this year. (There is always next year) while I have been away the class has filled up with some very fast 900 Ducati`s and 1000cc Moto Guzzi`s so was very competitive. I managed a 6th place which was not great but was 2 seconds a lap faster than last year at Calafat, so I was pleased with that. We had quite some carb setting issues in the training and qualifying mostly when I was on a neutral throttle through the esses. The temperature was quite warm for mid October 30 Deg C and we ended up dropping down to 230 main jet on one carb and 240 on the other to get both cylinder Heads close on temperature. One running at 198 deg C and the other 189 deg C. once on the main jet the bike was strong but could not match the speed of the big twins down the straight.
I need to look at the brakes in the winter as I was struggling with the single disc to stop the bike into some of the tight bends when trying to pass other bikes.
I hope to get out in January at Valencia if we can find a new set up for the brakes and work on the carb settings.
look forward to see your bike after you make the winter revamp.
cheers
Eamonn
Top
 Profile
PostPosted: Sun Nov 05, 2017 6:44 am
Offline
Hello Eamonn,
We were treating the Brands meeting as a test for 2018. Tragically a rider was killed on the Saturday and all racing was canceled. On the Sunday 3 riders went down in the morning and all needed hospital treatment which left no doctors or ambulances at the circuit and racing for the day was again canceled. We did have a good days testing on the Friday (blue skies and sunshine all day) to dial in the race engine in. Much to my surprise we ended up 7 sizes up on the main jets compared to the dyno (280's to 360 left/350 right). The bike was going well and Gary was lapping in the low 56s with a best of 55.52s. The CHT's were in the 150-170 deg C range which I thought reasonable (air temp in the 10-14 deg C range).
We also run a single 290mm disc up front with EBC "Green" organic pads. Gary has found this set-up to be very effective, although the colour of the disc after a race shows that it is getting very hot :D . No reports of brake fade though over our rather short 6 lap races.
Good luck for 2018 :up:
Cheers Geoff
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:53 am
Offline
Geoff
Sorry to read about those incidents at Brands especially the tragic one.
Interesting you were running such big jet sizes and I seem to go in the other direction. Ok the temperature plays a part and Calafat is by the sea, However that is a big difference. My engine runs to 8500 max I shift at 8300. Run 36mm carbs & bacon pipes I guess also no two engines are really the same.
For the brakes I think the problem is as we only get the one race its 12 or 15 laps depending on the circuit, usually the race works out to be 50km. Also my fault I never use the rear brake, so its all on the front.I will order some of those EBC Green pads for my January test
keep you posted on the progress
Eamonn
Top
 Profile
PostPosted: Sun Nov 05, 2017 7:55 am
Offline
sorry they are Abcon pipes
Top
 Profile
PostPosted: Sun Nov 05, 2017 9:09 am
Offline
Hi Eamonn,
I was making the assumption that you also used AP Lockheed calipers so the pads I use may not be available for your set-up. These pads do wear at quite a fast rate compared to others so you have to keep an eye on them.
Yes, the change in jets we used at Brands were also a surprise to me. The atmospheric conditions in the dyno room were a fair bit different to Brands on the day though. Our race engine runs 38mm VM Mikunis, fuel was a 50:50 blend of 100LL Avgas/Premium unleaded and oil Castrol A747 @ 20:1. Our engine drops off just before 8000rpm and makes 60bhp/46 lbs.ft torque at the rear wheel. We would like a few more revs and plan to address this over winter.
Yes, no two engines are the same :D Chris Kirkby with his 5-port barrels is running 450 main jets :o .
Cheers Geoff
Top
 Profile
PostPosted: Sun Nov 05, 2017 10:16 am
Offline
Geoff
thanks for the Pad reference I also run Lockheed so will give those a try.
We did a test at Zolder Beligum after Thierry finished the bike back in April and we compared the 107 Octane race fuel we ran last year compared to Shell V-Power 100 Octane Pump fuel available at shell stations and it ran better on the 100 octane Shell so we stayed with that this year. I changed to ELF oil and run premix only at 3%.
The ELF HTX976+ is much thicker than the Castrol 747 so needs to be mixed well, We had started with the ELF at 4% but it smoked a little so we dropped it down to 3% and it seems to be OK.
Eamonn
Top
 Profile
PostPosted: Sun Nov 05, 2017 11:04 am
Offline
Geoff forgot to say if you do Facebook search "Senior Moments Race Team" you will fin some photo`s etc from the Spanish Championship which I put on there.
Eamonn
Top
 Profile
PostPosted: Sun Nov 05, 2017 2:30 pm
Online
Country: England, UK
Oh and I thought they were smoking bacon pipes! I like smoked bacon. Abcon doesn't sound anywhere near as tasty. Lol :wth:
Top
 Profile
PostPosted: Sun Nov 05, 2017 4:01 pm
Offline
yes I do miss the smokey bacon your right the bacon just does not sound as good :clap:
Top
 Profile
PostPosted: Wed Nov 08, 2017 1:59 pm
Online
True, and possibly the bacon doesn't give as many horse power. If it did....I guess we would have to call it pig power instead!
....I wonder if a bacon exhaust could combine two of the worlds greatest smells; burnt 2-stroke oil and sizzling bacon.
Perhaps i am taking an already ridiculous topic to its extreme conclusion, but my mind likes to ponder these problems. It stops me worrying about serious stuff instead. Sometimes I'd like to Danepak up my troubles in my old kit bag and ride, ride, ride.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 15 guests
Jump to:
Suzuki2Strokes.com
