Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Mon Jul 06, 2020 2:14 pm
Post new topic Reply to topic  [ 373 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25  Next
Author Message
PostPosted: Thu Oct 27, 2016 2:23 pm
Offline
^ Very nice Seeley!
Top
 Profile
PostPosted: Thu Oct 27, 2016 3:34 pm
Offline
Thanks Jim.
It really is a lovely bike. Can you imagine if Colin had also produced a road frame kit for the T500 or GT750, we can but dream :)
Cheers Geoff
Top
 Profile
PostPosted: Mon Jun 19, 2017 11:38 am
Offline
Fanfare or trumpets Ta Da. Finally collected the race engine from Graham File :D
A small issue with the NOVA clutch basket, but nothing major.
Cheers Geoff
Top
 Profile
PostPosted: Mon Jun 19, 2017 1:51 pm
Offline
Country: Switzerland
Suzuki 2-Strokes: T500 Suzuki, AJR Bultaco, Honda NS475
Hi Geoff
I just ordered a Nova clutch for my T500 what was the issue you had with yours?
Thanks Eamonn
Top
 Profile
PostPosted: Mon Jun 19, 2017 3:50 pm
Offline
Hi Eamonn,
If you intend to use the Suzuki helical primaries you will have no issues. I also have the NOVA straight cut Primaries and it runs on a needle bearing vice the Suzuki bronze bush. Inside the needle bearing there is an insert/spacer (the std Suzuki also has one) The NOVA version appears a smidgin too short and when you torque the retaining nut it pinches the inner basket against the outer basket and locks up inner to the outer (if I have explained it right :lol: ). A simple fix if the spacer is under size and NOVA will replace it. Failing that I have ordered up some 0.1mm shims which will solve the issue.
With the NOVA basket you will need to de-rivet the old helical primary. When I did it I ground off the head and used a punch to knock the old rivets out. CAUTION I also cracked the Suzuki basket around the rivet as I did so. Not so much of a problem as you have the nice NOVA basket to replace it. I would recommend drilling partway down through the old rivets so they can crush as you knock them through. When its apart you will see a set of cush drive rubbers, NOVA also sell these if they need to be replaced. There is also a full circle gasket (or cushion) which you need to re-use (although it might be available from Suzuki still). A worth while upgrade IMHO as on the race engine I have had no clutch slip, or drag.
Cheers Geoff
Top
 Profile
PostPosted: Tue Jun 20, 2017 12:54 am
Offline
Hi Geoff,
That is great information I really appreciate that. I will use the standard gears for now. I have only had time to do one race meeting so far this year as I have been busy at work. Did the 2nd round of the Catalan on the Suzuki and finished 5th in my category not great but ok. I also raced the National classic championship on the 350 Bultaco as it was at the same circuit on the same weekend and got a surprise by finishing 4th, the level is much higher and the riders tend to be younger.
How has your season been so far this year?
Eamonn
Top
 Profile
PostPosted: Tue Jun 20, 2017 2:10 am
Offline
Hi Eamonn,
Our season has been non-existent so far lol. As always "stuff" has intervened both for myself and Gary May who takes the Seeley out on track for me. Although the "cooking" engine was re-built after the melt down at Cadwell last year I really wanted to fit the "race" engine next so kept putting off entering any meetings until it was ready. The tuner, Graham File, then had some serious health issues (he had his heart Op only yesterday after waiting 9 months) and it has only just arrived home. Hoping we might be able to do the complete season with CRMC 500 A/C class next year (with spare engine). Got to sort the clutch and then take the bike to the dyno and get in a few test days. Maybe, just maybe, we can get to the last meeting at Brands Hatch in October (funds permitting)
Cheers Geoff
Top
 Profile
PostPosted: Tue Jun 20, 2017 7:38 am
Offline
A 0.1mm shim solved the problem :up:
Top
 Profile
PostPosted: Sun Jul 16, 2017 2:54 pm
Offline
Finally got the "Race" engine installed, hope it lasts longer than the last one (3rd time lucky :lol: )
Cheers Geoff
Top
 Profile
PostPosted: Mon Jul 17, 2017 8:21 am
Offline
Suzuki 2-Strokes: GT750 hybrids (x2) VJ23A RGV500 TS185 R250
looks great Geoff :up:
shame to wrap a fairing around it.
When / where is it's first outing?
_________________
Garry
I'm addicted to brake fluid, but I can stop anytime.
Top
 Profile
PostPosted: Mon Jul 17, 2017 2:19 pm
Offline
Hello Garry,
I would like to get out, with Gary May onboard, at the last CRMC meeting at Brands on the 7-8 October. Depends on how it goes at the dyno etc. Got it running for the first time today.
https://www.flickr.com/photos/zunspec/35808508652/in/dateposted-public/
Cheers Geoff
Top
 Profile
PostPosted: Fri Jul 21, 2017 6:14 am
Offline
Sounds good :up:
_________________
Top
 Profile
PostPosted: Sun Aug 20, 2017 3:13 am
Offline
We took the bike to the dyno on the 17th Aug. Apart from the fact that I arrived early, and then discovered I had left the Laptop behind which programs the HPI ignition resulting in a 3 hour round trip to go get it, we had a good day. We were almost sent down a rabbit hole when the engine just did not perform and we suspected the HPI ign. was playing up. Happily a new set of plugs brought it all back :up:
https://www.flickr.com/photos/zunspec/36257380770/in/dateposted-public/
Here is a dyno graph, the "red" trace is from the 34mm Carb "cooking" engine for a comparison. Not WOW type figures but it should result in a very strong and drivable bike. The atmospheric conditions were not optimum for power reading so on a cooler day we might had nudged into the 60 bhp region.
Cheers Geoff
Top
 Profile
PostPosted: Sun Aug 20, 2017 7:43 am
Offline
Geoff , have you thought of running 38mm carbs ? as Kevin with his race 750 engine is getting over 40hp per cylinder with the 38mm VM carbs .
_________________
Top
 Profile
PostPosted: Sun Aug 20, 2017 8:18 am
Offline
Hi Dave,
I am running 38mm Mikuni VM carbs. This engine does not have a hot state of tune porting wise. There is a lot that can still be done but until I establish a reliable base line (after my previous engine failures) I am taking it steady. 40 bhp/cylinder is very impressive though, I would like to understand what Kevin has done to achieve this for the future development of my engine.
Cheers Geoff
Top
 Profile
Who is online
Users browsing this forum: No registered users and 14 guests
Jump to:
Suzuki2Strokes.com
