Page 9 of 12
Re: T500 Special Engine (Ported) Rebuild
Posted: Tue Feb 07, 2017 2:55 pm
by Zunspec4
Wow, spot on John
Sounds very crisp and proper. Yes. A747 has a much better fragrance than the hi-tech synthetics, not up to Castrol R standards but pretty good. I believe that A747 contains the equivalent of a synthetic Castor oil. Although it has been around for quite a while and there are other good alternatives which also suit old air-cooled 2-st engines.
Have patience with getting the carburation sorted, like me you will end up with good range of jets before you are finished
Posted: Tue Feb 07, 2017 3:07 pm
by johnu
johnu wrote:Well I got around to firing the bike up today, started on the second kick
Sounds way better than before but very woolly down low. Smoked like a chimney too. Fuel tap started leaking so I'll get that fixed and take it for a quick spin.
Geoff that 747 smells bloody good
https://www.youtube.com/watch?v=-IAjMbp ... load_owner" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
So a quick read of Graham Bells book tonight to brush up on jetting basics
Posted: Tue Feb 07, 2017 3:09 pm
by johnu
Thanks Geoff!
Yes I see a large jet collection in my future
John.
Posted: Wed Feb 08, 2017 9:22 pm
by johnu
Going to try to install this bad boy tomorrow, did I ever mention I hate electrical stuff
Posted: Mon Feb 13, 2017 5:18 pm
by johnu
Got the Acewell on but it is really erratic (tacho). Tried 2 coils around the plug lead and 5 coils but both the same. Going to pick up some resistor plugs to see if that makes any difference.
Posted: Thu Feb 16, 2017 5:17 pm
by johnu
Tacho working well now after installing resistor plugs
Now to work on the carbs, adjusting the air screws seems to have no effect at all on how the engine runs. Also screwed the slide stop screws all the way in and it still won't idle.
Posted: Thu Feb 16, 2017 6:08 pm
by Jimroid
Tell us exactly what it is doing. Starting ritual? Does it accept any throttle? Can those slides be put in backwards?(doubtful, but some can) Ambient temp and elevation? Video?
Posted: Thu Feb 16, 2017 6:45 pm
by johnu
johnu wrote:Tacho working well now after installing resistor plugs
Hi Jim, not sure if you saw my video from last week
https://www.youtube.com/watch?v=-IAjMbp ... load_owner" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; it ran ok but seemed woolly on the bottom end like it needs to go down on the pilots and it wouldn't idle. I ran it again today to try to get it to idle by adjusting the slide stop screws but they didn't do anything which seems strange. It starts up first kick cold with choke and it idles high as you would expect. Once I take the choke of it won't idle. It revs up quite nicely as you can here in the video. I really need to ride it but I can tell it will be very weak down low. I'm at about 1800ft elev and high 60's temp. I'm going to take the carbs off tomorrow and try to see what's going on.
Posted: Fri Feb 17, 2017 9:27 am
by Jimroid
Watched the video. I think I would be inclined to go from the #40 pilots to #35 or at least #37.5 and get it out on the road, under load and up to temp.
Posted: Fri Feb 17, 2017 11:34 am
by johnu
Jimroid wrote:Watched the video. I think I would be inclined to go from the #40 pilots to #35 or at least #37.5 and get it out on the road, under load and up to temp.
I think that's what I'll do. I actually have 45's in there and i'll go down to 40's.
Posted: Sun Feb 19, 2017 11:27 am
by Jimroid
Any progress?
Posted: Mon Feb 20, 2017 9:26 am
If going down in pilot jets doesn't start to respond to air screw and idle speed screw, try a #60 and see if that drowns it or cleans it up.
Posted: Tue Feb 21, 2017 4:37 pm
by johnu
Been so busy with work no time to work on the bike yet. Thanks for the suggestions though.
Posted: Thu Mar 09, 2017 4:12 pm
by johnu
Finally a little time to work on the bike
Just took my carbs off to change the pilots to 40's (currently 45's). Air screws aren't doing anything when I try to adjust them, in or out changes nothing so I'm trying the smaller pilots. I also noticed that the slides on both carbs have different gaps at the bottom when they are both all the way down. The right side is 4.5mm and the left is 3.9mm they are both 2.5 slides. Not sure it matters when the idle is adjusted using the tapered idle screws. Would think that the machining tolerances are way closer than that.
Posted: Thu Mar 09, 2017 7:45 pm
by Jimroid
Pull the slides out and stand them face to face to compare the cut out.
