GT250 Cafe - Build Experiment
Re: GT250 Cafe - Build Experiment
Your fabrication skills get better all the time. That's some amazing work.
Tom Garcia
Country: USofA
Post by Tom Garcia »
rngdng wrote:Your fabrication skills get better all the time. That's some amazing work.
Thanks Lane! They still leave much to be desired..."don't look behind the curtain"... One of the issues with this build is the clutch cover that was opened up for the dry clutch. I had to TIG the aluminum ring that holds the big oil seal into the cover. I did 90% of the welding as my first job after getting my first TIG...bad mistake... Lots of cleanup and I will need to get a slight bow out of the cover...
Tom Garcia
Country: USofA
Got the coil mount fabbed up and the sprocket cover cut and rough polished...
Tom Garcia
Country: USofA
Got out at O'dark Thirty and cut out the new "points" cover. Dished it a bit and polished it up. I know I have a bag of the proper NOS screws...just need to dig them out of their hiding place....
Also got the pickup assembly fastened together so it will go on today sometime after I return from Harbor Freight...can't find my chain breaker darn it...
HAPPY NEW YEAR EVERYONE!!!
Tom
Tom Garcia wrote: after I return from Harbor Freight...
Tom
Got my on line 1 day offer from HF with a 25% off coupon .. i hate it when they tempt me like that :?
Tom Garcia
Country: USofA
Tom
Yes.. 25% off the tap and die set and a FREE 20-pack of AA batteries..
Last time in there i used a 20% off on 2 of the gadgets you roll your bike up on so it easier to maneuver the bikes around in the garage to get them close to the wall http://www.harborfreight.com/low-profil ... 95896.html" onclick="window.open(this.href);return false;
Tom Garcia
Country: USofA
Got the ignition pickup finished and installed...side cover on...new points cover on... Shortened the chain to length and installed it... Sprocket cover finished and installed... Cut and threaded the shifter link rod and got that whole mechanism working...
Massaged the clutch cover and will work more on that tomorrow...
Tom Garcia
Country: USofA
More time to play today so I decided to fab up the guard for the whirring clutch. Sheet aluminum mounted with some S/S cap screws. Trimmed it a bit in depth once bolted on and mocked up with the clutch pack. Another half moon...a little TIG action....and some rough polishing. If I get some more time tomorrow I'm gonna try to "sex it up" a bit...
Like I said earlier.......skills improving.
Tom Garcia
Country: USofA
OK...went out this morning and added some sexy to the clutch guard...
garry55
Post by garry55 »
great work :up:
Garry
Tom Garcia
Country: USofA
Not much real work...older kids in from out of town and business trip to Baltimore last week. Throttle cable is on but need to drill and tap the grip housing for the larger cable end threads.. Small work done on finishing up the right side cover but still needs final polish. Once that is done I should be able to complete the clutch-side assembly. I did order some stainless for the chambers that should arrive Saturday....
At this pace you will be ready for this yrs Gap meet :up:
cobraace
Post by cobraace »
So glad to see this progressing :up:
