Titan twingle
Re: Titan twingle
Cool project all right :up: if the body of the chamber could be worked out to be under the engine the cornering wouldnt be a problem at all Image
diamondj
Re: Titan twingle
Post by diamondj »
Curious as what you did to modify the oiling system and eliminate the oil pump? Looks like a neat project. Any thoughts on a shorter swing-arm or possibly bracing the stock swinger?
old t500
Suzuki 2-Strokes: T500
Re: Titan twingle
Post by old t500 »
Holy cleanliness Batman!!!
Jimroid
Re: Titan twingle
Post by Jimroid »
To delete oil injection I did the following: (outside bearings) bored hole from bottom of transfers to factory oil supply passage, removed the slingers ,new seals with assembly lube,plugged all four injection inlets wth Loctited set screws, removed tach/pump drive and plated off. Two inside bearings are fed from transmission, so no change there. I will use an electronic tach,32/1 Maxima M premix. I do not want a shorter swingarm for drag racing.
Jimroid
Re: Titan twingle
Post by Jimroid »
I finished the wiring( not much to this but was waiting on a Pingel tether switch),finished front brake and came up with the muffler hanger. Time to gather a buddy or two and get the bike out of the basement and into the garage. I hope to have it fully assembled and running by Thursday.
Jimroid
Re: Titan twingle
Post by Jimroid »
What a heavy turd! I am at 316# already with one strut off, no shifter lever, no lithium battery(2#), no fuel(6#). It will be right at 326# on the starting line. Many heavy parts still on it like stock sidestand, big arse silencer, forged steel footpegs, etc. I don' t have a battery for it, so I have not started it yet.
Re: Titan twingle
Re: Titan twingle
Jimroid
Re: Titan twingle
Post by Jimroid »
Thanks for that Dave. I already tucked the loose wire in. I have also decided to add a small fuel resevoir right between the filter and carb inlet. I want to make sure the big boy carb does not starve at full prolonged throttle. There is 8" of head from the bottom of tank to carb bowl, but 5/16" hose is 24" long.
D&D CHASSIS
Country: usa
Suzuki 2-Strokes: GT750 dragbike
Re: Titan twingle
Post by D&D CHASSIS »
Not using a stock gas tank?
Jimroid
Re: Titan twingle
Post by Jimroid »
No, fuel is in the tail section. Ironically weight bias is exactly 50/50. I am still amazed how heavy the engine is on these.
Re: Titan twingle
Jimroid wrote:No, fuel is in the tail section. Ironically weight bias is exactly 50/50. I am still amazed how heavy the engine is on these.
You should pick up a GT750 engine :shock:
water cooled
Re: Titan twingle
Post by water cooled »
Very nice bike...!! When and where do you plan to debut it?
Jimroid
Re: Titan twingle
Post by Jimroid »
I'll start with my local track for test and tune. Many unanswered questions at this stage. Looking for a shift lever right now.
Jimroid
Re: Titan twingle
Post by Jimroid »
Link to videos: http://t500twingle.blogspot.com" onclick="window.open(this.href);return false; Edit: may only work from computer and not phones?
