New shocks + test fit of rearsets:
Rearset adapters worked out nicely.
1973 GT250 cafe build
Re: 1973 GT250 cafe build
Test fit of rearset on other side. Adapter worked out nicely. (The left & right adapters are different.)
The shift linkage rod is for a T500 motor & will need shortening.
Will need the kickstart lever mod.
- Flywheel
- Suzuki 2-Strokes: 1974 GT185
Looking good! That GT250 is going to be a head turner when done. Thanks for posting pics!
- smokin_blue
- Country: usa
Looking really good!
Now you just need to find a T350 top end to bolt down on to the bottom end like this....
If you want more details go to the Smokin Blue link on
http://www.street-unique.com/
'07 Suzuki SV650
'90 GSX-R1100 streetfighter
'72 T500 with a Lyster frame
'69 T500-parts/project?
'83 GR650-project
Past bikes
'06 Triumph Sprint ST
'86 GSX-R750
'74 GT250/T350 custom
'79 GS750
'74 TS250
'81 TS100
'83 GR650-project
Past bikes
'86 GSX-R750
'79 GS750
'74 TS250
'81 TS100
Nice bike!
I have 3 T350s, so I understand the surprising performance gain from the modest displacement increase (247 to 315cc).
We are building 2 cafe racers. I thought about a T350 top end. But as these are our firsts builds, so I'm trying not to do too much.
Test fit of seat.
Slowly making progress. Now has mini gauges & headlight bucket.
Oh the horrors. Am using an aftermarket Harley ignition switch & bracket.
Right-side T500 rearset worked out nicely. Will deal with the rod length after we have the seat on.
Right side looks good with rod adjusted & brake cable installed.
Left side will work out too. I modified the shifter shaft adapter — still needs a bit more work. Looks like the rod will need shortened a bit.
