Page 6 of 10
Re: BIMOTA GT1 Project
Posted: Mon Mar 20, 2017 1:59 pm
by wolfgangh
Posted: Mon Mar 20, 2017 5:06 pm
by RING_DING
Coming along nicely Wolfgang! Your attention to detail is superb
Posted: Mon Mar 20, 2017 5:24 pm
by Suzukidave
Very nice
You arnt going to be able to ride it anywhere without drawing a crowd
Whats going on inside the engine that you can share ?
Posted: Wed Mar 29, 2017 3:09 am
by rngdng
Suzukidave wrote:Very nice
I see a lift plate......
Posted: Wed Mar 29, 2017 7:25 am
by Suzukidave
Good eye Lane
maybe 3mm ?
Posted: Wed Mar 29, 2017 6:18 pm
by wolfgangh
There is not so much done inside the engine - I bought the engine as is. 3mm cylinder spacer, TR750-like porting (previous owner opted for 32mm exhaust from TDC - I hope this is not too radical!), cylinderhead shaved off 1,5mm, BARTON close-ratio gears, VM32 carbs, ACCENT ignition, JEMCO pipes.
Since I am not looking for a race bike and the engine tuning seems to be on the radical side, I am planning to change barrels and head over winter to a more conservative version. I want torque. I will try it as is first.
Posted: Wed Mar 29, 2017 7:03 pm
by Suzukidave
I am pretty sure what ever spacer you add under the cylinder you have to remove a like amount from the top just to keep compression the same , for a torque engine stick on some reeds
Posted: Wed Mar 29, 2017 8:36 pm
by wolfgangh
Of course the barrels have been shaved off by 3mm. Correction on the carbs, they are VM34.
Posted: Thu Mar 30, 2017 1:41 pm
by Suzukidave
wolfgangh wrote:Of course the barrels have been shaved off by 3mm. Correction on the carbs, they are VM34.
Sorry , should have known better than to suggest
Posted: Tue Apr 04, 2017 3:01 am
by rngdng
That engine set-up is a lot like mine. It still has a good bit or torque.
Posted: Tue Apr 11, 2017 1:32 pm
by wolfgangh
Made good progress this week.
Completed engine assembly, installed Accent ignition, and mounted VM43 carbs and JEMCO Pipes.
Fitted an external gas tank and started engine time. This thing is so F....g loud, I dont think any real TR750 was ever louder. Besides gettign air filter pods mounted, there is not much more left to reduce noise. I seriously cannot imagine how anyone can ride his kettle on a public road with JEMCO´s - I dont think a stock airbox makes such big difference. Don´t get me wrong -I love this sound, but it makes it impossible to use this bike in my country. I hope I find ways to reduce noise level significantly. Any ideas welcome.
Here is a short video - turn volume to max to get an idea of what I am talking about
https://youtu.be/qkUVLFUDM4o
Posted: Tue Apr 11, 2017 10:28 pm
I think that the muffler volume is too small and the steel shell resonates.
As a quick fix, see if you can find aluminium tube that slips over the existing muffler shell. It 's a tight enough fit (no rattles) it will reduce noise radiated out from the side of the can.
If that doesn't work or work well enough, try to cut the outer muffler shell off and fit an adapter and larger bore aluminum outer sleeve and more sound absorbing mat around the stock core.
You might also try a smaller core perforated tube, but too much smaller and it will overheat.
If that is still not enough, you may need to design a different baffle arrangement, but try larger volume and softer outer skin (Al) first.
Posted: Wed Apr 12, 2017 6:14 am
by fredvincent
This raises a question I was going to ask as part of my upcoming GT500 race rep build - Gordon Jennings advocated in his book that trials with extending the tailpipe into the baffle cone reduced noise and in some cases increased power slightly. Does anyone have any evidence that this has been tried since he wrote the book back in the 70's?
Posted: Wed Apr 12, 2017 6:24 am
by Suzukidave
On my last custom GT i used this idea when building the chambers , i inserted the stinger into the last cone . The exhausts are still quite loud but i cannot tell how loud they would have been in normal fashion .
Posted: Wed Apr 12, 2017 6:53 am
by smokin_blue
I ran internal stingers on the pipes on my GT250/T330 build shown in my avatar.
