A Katana................in here................?????
garry55
Re: A Katana................in here................?????
Post by garry55 »
thanks for the info guys - most helpful :up:
I'll be back with more questions real soon............. :wink:
Garry
garry55
Post by garry55 »
got a call today to say the rear footrest mount modifications were complete, so off I went to collect the frame. The rear footrest and silencer mount have been removed, saving at least 10kgs of weight, and the front footrest mount triangulated so............
much neater - much lighter.
Back home in the garage, I fitted the front and rear ends then test-fitted a spare motor to see if all the newly attached engine mounts lined up................
they did - perfectly :up: Just the upper rear mounts to make now I can get the exact measurements for them.
Left-side footrest mount.........
sits just right and well away from the rear shock line - result :D
and the exhaust ports.............
clear of the frame tubes - just as Suzuki designed them to be.
Garry
garry55
Post by garry55 »
I am still a bit concerned that the motor doesn't "fill" the frame fully. Tomorrow I am going to fit the front fairing subframe and attach the side covers to see if they close the gap.
Otherwise, it's looking like a supercharger............. :D
Garry
Don't worry about "filling" the frame. Besides, superchargers don't work very well on two-strokes anyway.
dgoodsy
Suzuki 2-Strokes: '72 gt750
Post by dgoodsy »
rngdng wrote:Besides, superchargers don't work very well on two-strokes anyway.
Explain to a rookie why this is? In my inexperience I expected turbochargers to cause problems due to increasing exhaust backpressure but superchargers, not restricting the exhaust, would work better in most scenarios. educate me please.
Also cool update Garry. Have you any idea what type of supercharger you might use?
'72 GT750
The main thing i could think of the supercharger creating a problem would be with the bottom end seals , they are not designed to retain much psi , i know even when doing a leak down test it is suggested to use not much pressure more pressure than 5~6 psi . But with most things .. if there is a will there is a way . Trains use superchargers on there 2 stroke diesels .
dgoodsy
Post by dgoodsy »
yes, that makes sense. It would apply to any type of FI then, not just superchargers.
Weren't some of the 2 stroke Detroit diesels supercharged?
'72 GT750
garry55
Post by garry55 »
guys - the supercharger comment was a reference to comments made earlier in the thread - I think SuzukiDave and TZR made the same observation in fun :up:
The gap is as it is and will stay that way. I did notice that on the other side of the motor, the thermostat housing adds height to the head and fills most of the gap - maybe I should graft a false housing onto the left side? :lol:
Garry
dgoodsy
Post by dgoodsy »
I see, I didn't realize the comment was in jest. Carry on with the awesome updates!
'72 GT750
I think that the gap will look terrible. Maybe time to cut up the frame and raise the motor and maybe lower the tank and seat at the same time.... :roll: :up:
garry55
Post by garry55 »
you and your ideas - I am still trying to build the stacked gearbox you suggested a while ago........... :D
Garry
How is that coming along? Shorter motor would allow you to move the swingarm pivot forwards and fit a longer swingarm.
Fitting a supercharger would be easier. :? Keep having fun.
garry55
Post by garry55 »
been struggling to find a home for the battery, as it's usual place has been taken by the 2-stroke oil tank. But tonight, I had a Eureka moment, so it was out with the marker pen, drill and files..........
just a bit of cutting and grinding to do on the underside of the swing arm to get the battery box to sit flush
Garry
Put a pair of false breasts in the gap.
No one will notice that there should be anything else there - or not.
Less setting up than forced induction and won't affect the intake suction.
garry55
Post by garry55 »
the battery box, finished at last..........
Garry
