Page 3 of 5
Re: V4 RGV500
Posted: Mon Nov 14, 2016 4:43 pm
by garry55
the l/h side carbs, however, do not align as I had to turn the furthest left carb inwards to clear the frame spar. Only way to fit an airbox to these carbs was to saw the box straight across the l/h carb opening....
then fit that section to the carb, overley the other half, mark it and cut that section at an angle, giving me two usable parts and a scrap "wedge" piece..............
fitting the two parts shows I got it near enough.......
to be welded together to make one unit. I'll be doing that at work tomorrow
And yes - you are correct in thinking that these are not airboxes in the truest sense. They are there to prevent the carb slides from fluttering at speed.
Re: V4 RGV500
Posted: Mon Nov 14, 2016 4:56 pm
by garry55
and - I have 4 sparks
It looks increasingly like the Zeeltronic unit left the factory with no ignition maps loaded ( there are other RGV owners who have suffered the same frustration as me).
Re: V4 RGV500
Posted: Thu Nov 17, 2016 5:41 pm
by Suzukidave
Is it very difficult to create the map to run your engine on ?
Re: V4 RGV500
Posted: Sun Nov 20, 2016 3:46 pm
by garry55
No Dave - I just run a standard RGV250 map as it is 2 of those motors conjoined and the crank is phased so that the top cylinders both fire together, as do the lower 2. So one spark signal can fire 2 separate coils and 2 separate cylinders.
It runs like this so no undue loading is put on the crank centre joint.
Re: V4 RGV500
Posted: Sun Jan 08, 2017 5:02 am
by garry55
Yay
https://youtu.be/yucjyC2FEls" onclick="window.open(this.href);return false;
and yes - it is missing 1 stinger - it "fell off" when unloading the bike from the van (top tip -don't use them as lifting handles!)
Re: V4 RGV500
Posted: Sun Jan 08, 2017 6:17 am
by Suzukidave
Says video is private
Re: V4 RGV500
Posted: Sun Jan 08, 2017 8:37 am
by garry55
my bad - it has now gone public
Re: V4 RGV500
Posted: Sun Jan 08, 2017 10:31 am
by busa1300
Hearing it runs has to make all that work seem worth it....making a dream reality takes work.
Re: V4 RGV500
Posted: Sun Jan 08, 2017 6:54 pm
by Suzukidave
All right
and sounds so good too
Re: V4 RGV500
Posted: Wed Jan 11, 2017 5:08 am
by rngdng
FANTASTIC!! It sounds perfect.
Re: V4 RGV500
Posted: Mon Sep 04, 2017 3:51 pm
Gary, if they are the same as the test sample I bought to evaluate, the perforated baffle tube is much larger that teh end pipes and although the outesr skin is pretty thin, they may just work with a small amount of modification
Re: V4 RGV500
Posted: Tue Sep 05, 2017 4:54 am
by garry55
TeeZee -I have binned them now as I am having a set of pipes made which will have the stingers attached.
Just completed fitting and blending the power valves (it had blanks fitted for test purposes), have to make mounts now for the 2 power valve motors.
Re: V4 RGV500
Posted: Tue Sep 05, 2017 8:50 am
No worries. BTW, if you have run an RGV you already know this but how you set up the power valves has a significant effect on the shape of the power curve. - at least it did on our RS250 Aprilia Cup bike. With two 65 hP motors connected, you probably want to set thee cables up loose so they open later. I cannot imagine what that beast will be like when it comes on the pipe.
Re: V4 RGV500
Posted: Tue Sep 05, 2017 12:53 pm
by garry55
good advice
I can programme the opening curve of the p/v's with the Zeeltronic controller, so we will have a play on the dyno and aim to bring them in steadily. The motors are not tuned, so only around 52-ish hp each.
Wonder what it would be like if I used the 300cc conversion kits..............
Re: V4 RGV500
Posted: Sun Apr 05, 2020 3:59 am
by garry55
It's back in the garage!!!!
chassis in the back ground is going to be it's new home - a 1999 SRAD 600.
20 minutes later..................
