Page 7 of 10
Re: BIMOTA GT1 Project
Posted: Wed Apr 12, 2017 1:14 pm
by wolfgangh
Do you think it might help / do not do any harm to the engine if I reduce the ID of the holed tube in the muffler from 27mm to something smaller? This would create more volume for packing material - my concern only is that the engine might get too hot due to backpressure from the smaller tube acting as a vent.
Posted: Wed Apr 12, 2017 5:24 pm
by Suzukidave
I believe the stinger opening should be close to 1" (26mm ) - a couple of mm shouldnt hurt . You could remove the stock silencers and put on some that have more packing .
Posted: Thu Apr 13, 2017 7:05 am
by smokin_blue
I would not go any smaller on the stinger diameter. You won't gain enough volume to have an effect. I would go with the other suggestions of remove the cans and replace them with larger diameter ones to allow more packing. The other thing would be to review what packing they have if any. Depending on the design they might not have any packing in there or it may not be that effective. I would start there and then increase can diameter only if you need to.
Posted: Thu Apr 13, 2017 12:58 pm
by wolfgangh
Here are pictures of the muffler internals- The damping material is only 5mm thick and 200mm long. I think I may go with larger OD and longer end piece to increase the volume of the muffler.
Posted: Thu Apr 13, 2017 6:23 pm
by Suzukidave
Jemco didnt do too sporty a job wrapping those silencers huh
Posted: Fri Apr 14, 2017 12:44 am
Better to use stainless wire to hold the baffle wadding. When the tape melts it will start to move where it wants, and exhaust can't get through tape in any case, so the wadding can't work very well.
Posted: Fri Apr 14, 2017 3:51 am
by old racer
That is not even baffle material It's glass fibre matting for layup.
Along with that tape wrapped around it i doubt it's doing much to silence it.
Posted: Mon Apr 17, 2017 11:33 am
by wolfgangh
Posted: Mon Apr 17, 2017 11:41 am
by simmons1
Looks awesome!
What are you using for carbs, and do you plan on using the oil pump?
Thanks!
Rich
Posted: Mon Apr 17, 2017 12:16 pm
That's the best kind of woman. never talks back!
She looks a little bit, er, cold though.
Posted: Mon Apr 17, 2017 1:10 pm
by wolfgangh
Hello Rich, these are Mikuni VM34 carbs and yes, I will use the oil pump. Its not going to be a track bike, I want to use it for sunday morning rides and some club gatherings, shows etc..and dont want to mess around with oil / gas mixing.
My pil pump is currently leaking, I ordered the gasket and seal to rebuild it. For the heat cYcles, I currently run 1:30 premix
Have also ordered a set of RAMAIR filters, both cylindrical ones and oval ones. Will see which ones fit better.
Posted: Mon Apr 17, 2017 3:52 pm
by simmons1
Thank you!
I would like to get rid of the CV carbs, once I get my cooling system issue fixed.
Posted: Mon Apr 17, 2017 8:11 pm
34mm carbs will make more power, but CV carbs are better than you might imagine. Mine has run 12.8 quarter miles at 111mph with stock CV carbs and Bob Prior in the land downunder has run faster than that on CV carbs too.
For top end though and looks, VM34 or larger are better
Posted: Mon Apr 17, 2017 8:33 pm
by Suzukidave
I am pretty sure the head gasket should stop any coolant leakage around all the head bolts . Re torque maybe ?
Posted: Mon Apr 17, 2017 8:50 pm
by simmons1
Suzukidave wrote:I am pretty sure the head gasket should stop any coolant leakage around all the head bolts . Re torque maybe ?
Wrong thread but I already retorque the head.
