1972 GT550 cafe build - new topic
texranger
Country: United States
Suzuki 2-Strokes: 1973 & 1976 GT550
Re: 1972 GT550 cafe build - new topic
Post by texranger »
Stunning...love the color! Great job
Some carb adjustments & now idling nicely. Itching to get the side stand finished so I can go for the first test ride.
jabcb wrote: Fri Apr 09, 2021 1:22 pm Itching to get the side stand finished so I can go for the first test ride.
Make sure it's 'up' before you set off!!! :shock: :lol:
Test fit of modified side stand — looking good. Should have the bike on the road soon.
Imagecafe-GT550-1886 by jabcb, on Flickr
Side stand finished.
Imagecafe-GT550-1913 by jabcb, on Flickr
Looking good. :D
Imagecafe-GT550-1917 by jabcb, on Flickr
Zunspec4
Post by Zunspec4 »
WOW 8) 8) 8) 8) jabcb. Seriously sweet machine :up: :up: :up:
Thanks. But, rats.
Petcock leaks around a drip every 10 ~ 15 seconds. It’s a reconditioned petcock that I bought from somebody a few years ago.
Plus float bowl gaskets weep a bit — perhaps because of the leaking petcock.
Wanted to have it ready for a local show next weekend. So I’m looking into doing a manual conversion of an old petcock.
Difficult to use an inline tap unless you use a later single pipe version and a 3 way 'T' piece to feed the 3 carbs.
I’m converting an old GT-series 3-outlet petcock to manual.
Pretty straight forward: block off the two passages to the vacuum value with set screws + JBWeld, and flip the lever mechanism around. This gives you off (lever down), on (lever forward) & reserve (lever up).
If you can, post pics of the 'mods' to the tap and I'll 'sticky' the thread for others to easily find.
Petcock mod worked great. Will post a separate topic detailing the mods.
First ride — started & ran perfectly. But mother nature noticed a spiffy new cafe build on its first ride & the results are:
Imagecafe-GT550-1925 by jabcb, on Flickr
Oh, soggy heck (or similar). But on the upside, that gold looks well when wet.
Preferred the maximum-coolness look of a 3-into-1 + the 4LS.
Couldn’t go with the Jemco 3-into-1 like I have on the gray GT750. Jemco is back in business but they no longer make the 3-into-1s.
Higgspeed started making them. Here is a test fit:
Imagecafe-GT550-2245 by jabcb, on Flickr
A 3-1 does sound nice, and shouldn't make a blind bit of difference top end wise as the weight loss is significant.
