T575 Steam Triple
garry55
Re: T575 Steam Triple
Post by garry55 »
Alan H wrote:Weight saving. On a hippo, every hundredweight counts.... :up:
ain't that the truth............... :D
Garry
garry55
Post by garry55 »
wiring finished and tidied. The only item that doesn't work is the low fuel warning light. The tank switch is faulty and a replacement is £75,so that can wait.
GT750 J/K throttle cables and oil pump cable installed,along with a GT750 coolant expansion tank.
radiator cap easily accessible when the front cover of the fuel tank is removed.
fuel system next........................
Garry
garry55
Post by garry55 »
the fuel system - standard Triumph T595 (injection) system..........
and my simplified carb system.............
Fuel tap is mounted horizontally so either Fuel On or Reserve position feed fuel to the Mikuni 3-port vacuum fuel pump.
Fuel On position drains tank to tap level, Reserve position scavenges whats left via a dip tube.
But by then I should have a working Lo Fuel warning................
Garry
garry55
Post by garry55 »
bottom end built - Chris Applebee crank, refurbished water pump, all new seals and bearings and freshly powder coated satin black cases.
Garry
sportston
Country: England, UK
Post by sportston »
I like the fuel tap arrangement. What is 3 way distribution valve from?
garry55
Post by garry55 »
It's a Mikuni vacuum petrol pump. Available from Allens Performance.
Garry
garry55
Post by garry55 »
so I (and the next owner) know where all the wires go............
Garry
dollydog
Country: england
Post by dollydog »
you need to be cannonized for having the patience to draw that out :D
garry55
Post by garry55 »
got the air box back today -all neatly welded and fit for purpose.
Garry
garry55
Post by garry55 »
I made a blanking plate for the front of the plastic Triumph air box, cut 2 holes in the section above it for the inlet tubes and re-located the coolant expansion tank.
Everything now fits under the fuel tank and it's front cover, and the fuel tank is such a snug fit that it actually holds the air box onto the carb inlets, so no securing straps or brackets required.
Garry
garry55
Post by garry55 »
that's the rear suspension sorted....................
Garry
sportston
Post by sportston »
Cor that looks nice. Hope you still have your arms and legs left.
garry55
Post by garry55 »
sportston wrote:Cor that looks nice. Hope you still have your arms and legs left.
yep - but only 1 kidney.............. :D
Garry
sportston
Post by sportston »
garry55 wrote:yep - but only 1 kidney.............. :D
Thats ok. "Sorry I haven't got one spare," is a handy excuse if anyone asks you to become a donor. I hear kidneys go for good money these days, so at least you should have enough dough left to finish the bike. The welding on the airbox looks nice by the way
garry55
Post by garry55 »
Steam Triple sporting it's new 3-1 exhaust...........
some of the detail..........
Garry
