Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Wed Aug 15, 2018 9:28 am
Post new topic Reply to topic  [ 157 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11
Author Message
 Post subject: Re: My T500 cafe
PostPosted: Thu Dec 07, 2017 6:16 am
Online
Bikes owned: T500R, SV1000S, TS125, Seeley T500
Hi sbaugz,
You could fit a race tacho like the Scitsu. These are powered by an internal re-chargeable battery and the pick-up/sensor wire is placed alongside the HT lead. They can also be powered by the bikes electrics if fitted or an external PP3 9v battery. Scitsu tacho's are a very common choice in the classic race world.
Top
 Profile
PostPosted: Thu Dec 07, 2017 2:06 pm
Offline
Country: England, UK
sbaugz wrote:
Hello everyone. I haven't been on this forum in ages. I am still loving my T500 cafe racer. I sorted it all out this past summer and can't wait for next driving season.
It looks fantastic. What bike is the tank off?
Top
 Profile
PostPosted: Thu Dec 07, 2017 6:44 pm
Offline
Bikes owned: T500
sportston wrote:
It looks fantastic. What bike is the tank off?[/quote]
Its off a 1977-ish yamaha XS750.
I really love that particular tank. Its big (almost 5 gallons), and it has a great shape with knee dents built into tank. I also like that it has a HUGE tunnel, so it can fit over almost any frame backbone or engine. One more thing I like is that it has fuel outlets on both sides, so you can easily run one line to each carb without using a T fitting. Pingel makes an adaptor that works with this tank, allowing a simple gravity petcock to be used. Overall, I cannot say enough good things about these tanks. Oh, and they also make reproduction, brand-new gas caps for pretty cheap too.
Here is a before pic:
ImageIMG_2186 by sbaugz, on Flickr
Top
 Profile
PostPosted: Thu Dec 07, 2017 6:46 pm
Offline
Bikes owned: T500
i used the same tank on a XS650 build a few years back too. It was easy to swap the mounts around and configure the XS750 tank to work with the XS650 frame.
ImageIMG_0553 by sbaugz, on Flickr
ImageIMG_0852 by sbaugz, on Flickr
Top
 Profile
PostPosted: Thu Dec 07, 2017 7:30 pm
Offline
Do you have pics of the tank mounts you used?
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Thu Dec 07, 2017 8:39 pm
Offline
Bikes owned: T500
not really. I have some pics below but they don't really show the mount all that well.
The XS750 tank uses a cup piece on the tank and the rubber puck is on the frame.
All you need are two of these rubber pucks seen here: https://www.mikesxs.net/yamaha-xs650-fr ... 81-00.html" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
You then have to figure out a way to get those pucks mounted to the frame. In the case of the T500, it was pretty easy. The width of the frame happened to be the exact width between the mounting cups on the tank itself. All you have to do is mark where they should go. I then welded a steel rod to each side of frame. See first pic below. Then you place the rubber puck linked above onto the steel rod (see second pic) and the tank slides right on. Its hard to explain, but easy to figure out.
Take note of the location of the new mounts compared to the stock mounts which are still on the frame slightly in front or and below the new mounts.
ImageIMG_2451 by sbaugz, on Flickr
Top
 Profile
PostPosted: Fri Dec 08, 2017 3:01 pm
Offline
Aahh. I thought it might be from a Yamaha. I saw a similar tank on a Custom Triumph that came from a Yamaha. It looked great on that too.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 13 guests
Search for:
Jump to:
Suzuki2Strokes.com
