Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sat Jul 21, 2018 9:11 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
Author Message
PostPosted: Thu Aug 17, 2017 4:57 pm
Offline
Bikes owned: T500
ConnerVT wrote:
For the past few years, a small part of my day job entails writing procedures, work instructions, and Job Breakdown Sheets (JBS). I mostly fly a desk now, supporting factory automation, but spent many years turning wrenches on semiconductor production tools.
The carb tuning procedure I just shot from the hip, relying on my questionable memory. But I've gotten real good at pulling the carbs off my T500, adjusting/rejetting, and putting everything back together. I usually pull the seat, battery box, air box, then the carbs. Do it enough times, you can get back on the road in under an hour.
Your skills are apparent in both areas!
Top
 Profile
PostPosted: Thu Aug 17, 2017 7:00 pm
Offline
Bikes owned: T500R (now), T500M (30 yrs ago)
Thank you, but the praise is likely unwarranted. If I was that good, I wouldn't have needed to take the bike apart for the past 6 years, looking for a happy place for the jetting. :lol:
What is nice about the T500, is that it is very forgiving, and not difficult to get running well on the street. With a motor that has no vacuum leaks, you can be a degree or two off on the timing, a 1/2 turn of the idle mixture, and most riders won't know the difference. Some people go to great extent to squeeze every extra amount of performance from a 50 year old design, but I found it fun (and humorously amazing) just to tool around on a bike which the motor only requires 9 moving parts to run - 2 pistons, 2 connecting rods, a crankshaft, 2 carb slides, and 2 ignition points.
Top
 Profile
PostPosted: Fri Aug 18, 2017 1:35 pm
Offline
Country: England, UK
Yes it's great isn't it? That is the engineering beauty of a 2-stroke. Simplicity itself.
I find it hard to get too excited about any other engine as much. Nothing else has as much character, charm and ease of maintenance. And have you ever heard a 4-stroke sound as beautiful as a well-tuned 2-stroke in full song? Never!
4-strokes are high maintenance divas, beautiful in their own way, but I'd much rather live with a dirty little minx with a heart of gold and simple tastes. :)
Top
 Profile
PostPosted: Fri Sep 15, 2017 9:47 am
Offline
Bikes owned: T500
Howdy all,
It has been a bit since we last posted, but nothing significant to report on the progress until now. I managed to track down a new slide for the carburetor on eBay, plus some O-rings for the idle, mixture, and choke through a dealer in Utah. We spent some time yesterday finishing up the cleaning, polishing and painting of all the carb bits and finally re-assembled the right side carb.
We also got the cylinders cleaned and painted.
Currently, we're waiting on UPS to deliver some wintergreen oil which will be used to restore the carburetor boots. We've seen this used with varying degrees of success, so we're keeping our fingers crossed it will work. If it doesn't, oh well. It's just money!
Next step is dragging the crankcase up to Utah to finish cleaning and painting. Then on to engine assembly!
I would like to throw another inquiry out there about where I might be able to track down some transmission gears for this engine. I have been looking and asking around, but can't find anything. Any leads are greatly appreciated!
File comment: Original, dirty carburetor
File comment: A little paint and wire wheel go a long ways!
File comment: Cleaned and painted cylinder heads
Top
 Profile
PostPosted: Fri Sep 15, 2017 12:39 pm
Offline
Bikes owned: GT750 x2 97 -1200 Bandit 86 GSXR1100
Nice work cleaning up the parts :up:
_________________
Top
 Profile
PostPosted: Sat Sep 16, 2017 5:19 am
Offline
Looks great. What sort of paint did you use on the carbs?
Top
 Profile
PostPosted: Mon Sep 18, 2017 8:41 am
Offline
Bikes owned: T500
Thanks. The paint is just a plain-jane, high heat, gloss black aerosol.
Top
 Profile
PostPosted: Mon Sep 18, 2017 9:00 am
Offline
That is quite a contrast to what the carb used to look like.
Just thought you might want to think about removing the paint from the part where it clamps to the rubber on the engine side. If the paint flakes, cracks or degrades it might give you an inlet air leak, which can be a pain in the bum and sometimes cause engine damage due to a lean mixture.
Top
 Profile
PostPosted: Mon Sep 18, 2017 9:28 am
Offline
Bikes owned: T500
Thanks for the tip, Sportston. It did dawn on me after I had painted the carbs!!
Top
 Profile
PostPosted: Sat Sep 23, 2017 4:57 am
Offline
Lol. We all have 20/20 hindsight!
Top
 Profile
PostPosted: Thu Oct 12, 2017 10:02 am
Offline
Bikes owned: T500
Howdy,
It's crazy how life can change. My wife was recently diagnosed with breast cancer so the last month or so have been a blur as we have begun the process of treatments and doctors appointments. Needless to say I have not been back to California to pick up any parts on the bike. Instead, I have turned my attention to the wheels and tires recently.
We pulled apart the front wheel assembly down to its components and began cleaning that recently. The rims are in good shape for being 40 years old. Mostly lots of dirt and grime built up on everything. The spokes polish up very nicely with a wire wheel and some attention to detail.
By the way, in a recent post I mentioned I was going to restore the rubber intake boots for the carburetors. I used a mix of 1 part wintergreen oil and 3 parts rubbing alcohol and let them soak for about a week in a Ziploc bag, checking regularly. This process works miracles! Both boots, which were rock hard, are now soft and pliable with a lingering essence of wintergreen. I highly recommend trying this if you have any old rubber pieces that you want to salvage. I found the oil online through a livestock feed and supply store (it is used as a liniment on horses).
Top
 Profile
PostPosted: Fri Oct 13, 2017 3:28 pm
Offline
I hope your wife's treatment goes ok. Amazing how well you made the carb rubbers fresh again! I would never have thought of using horse liniment. However did you think of that solution?
Top
 Profile
PostPosted: Fri Oct 13, 2017 4:10 pm
Offline
Bikes owned: T500
Thanks for the thoughts. We're all praying for her!
The rubber restoration I have seen done on YouTube a few different ways, but the wintergreen oil and alcohol always seemed to yield the best results. There was one video in particular that compared different ratios of oil-to-alcohol as well as other methods (e.g., soak in brake fluid). Figured I had nothing to lose since I would have needed new boots anyways. I've had the boots out of the solution for about three weeks and they haven't hardened or changed at all. The oil was about $18 for a pint on Amazon. Here is a link if anyone is interested...
https://www.amazon.com/gp/aw/d/B00562VC ... ref=plSrch" onclick="window.open(this.href);return false;
Top
 Profile
PostPosted: Sun Oct 15, 2017 9:30 am
Offline
Its the thought of wasting the alcohol that worries me. Did it still taste ok afterwards?
Top
 Profile
PostPosted: Fri Nov 17, 2017 11:01 pm
Offline
Bikes owned: T500
Howdy all,
Not a lot of progress, but we are still moving ahead. Since the last update we pulled apart the front wheel and cleaned and polished the hub and spokes and reassembled the entire wheel. Then we scabbed together a po' boy truing stand with a step ladder, a screwdriver, and a C-clamp. Twasn't pretty, but it worked!
When we pulled the hub apart, the brake surface had a lot of rust that looked like it be too much to overcome with a wire wheel. Not to be discouraged I knocked down the rust with some 220-grit wet-or-dry sandpaper and some warm water and to my surprise it all came off and the wear surface of the drum was perfectly smooth!
My son pulled apart the triple tree and got the frame completely down to its bones and it is currently his class project for his autobody/painting class at high school. He thinks he should have it back by the end of November. We will work on getting the rear wheel cleaned and polished before he gets the frame back.
Once that is done, then begins the next step of reassembly. He's pretty excited to be getting to this step.
I haven't got any response from anyone, but I will continue to inquire...Does anybody have a line on some transmission gears for this bike?
File comment: Grungy and dirty wheel and spokes.
File comment: Homegrown wheel truing stand
File comment: Finished wheel assembly. Now we just need some tires!
File comment: Frame ready to go to paint.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 12 guests
Search for:
Jump to:
Suzuki2Strokes.com
