Heres my 750 A model in Canada, a constant work in progress when im near to it anyways.
So far ive rebuilt the ft forks, fitted new H.L ears and lower covers, tapered head bearings, repainted both triple trees, repaired the seat lock and added a steering lock that now works with all matching keys.
I also refurbished and repainted the front calipers and the master cylinder, re-zinced all the related bolts and fittings and fitted new brake hoses, disc pads and the related rubber parts are also new.
A new clutch perch and new levers, a new clutch cable, a new tach cable, a new speedo cable, new mirrors and damper bushings and new grips were also added.
Also added was a Euro spec GSX1100 handlebar, a rad crash bar that was in better shape than what was on the bike and i repaired the plastic rad cover and repainted it.
Then i polished the two sprocket covers and refurbished the alternator cover, added all new tank rubbers, a new sprocket up front, serviced the carbs and did the air jet mod with new intake boots on both sides.
A new chain, a new chain guard, a new rear tyre, rezinced the rear peg assys and replaced both inner pipes and the right one as well with better looking used units.
Plus i have refurbished the baffles, and fitted an NOS factory luggage rack,,,,,, the list goes on when i return.
