Any of you kind and gentle folks bought a ultrasonic cleaner. I see them advertised for $30 to $100 for small units 30W to 60W.
I wanted to clean carbies etc and other bits and wondered if they were any good. Could also clean my dentures...
Ultrasonic cleaners
- Fritz500
Ultrasonic cleaners
73 GT750 Ducati - 20%
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
Re: Ultrasonic cleaners
We have one Fritz. We have used it almost exclusively for cleaning carbs. I think it's about a 2 litre capacity, which is big enough to emerse a pair of 500 carbs. To be honest we need to research using it a bit, as I haven't been entirely impressed with it. Aluminium comes out very dull, and generally needs some further cleaning to get a satisfactory cosmetic appearance....but that may just be down to us not using the right ingredient. It does remove just about all the clag and deposits though.
I'm sure there was a thread here very recently, showing some carbs, possibly from a triple, that had been ultra-sonic'ed and they looked absolutely beautiful, much better than ours.
Perhaps someone will chime in with some useful recommendations.
- Fritz500
I'd be suprised if it removed whatever was making the actual alloy dull. I understand these devices remove dirt/grease etc. I assume oxides would require polishing or bead blasting.
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
- Suzuki 2-Strokes: '69 Rebel, '75 Indy
I bought one from harbor freight here. The same one was sold under different names. It has been great, still works great after lots of use. It is great on screws and small bits. NOT carb floats though. I've read that there are many types of fluids/cleaning agents to use for different jobs but all I've used is dish soap. Works great cleaning my reading glasses too
1975 GT550
- Fritz500
Can you PM the brand name/s? I might check them out on FeeBay.bill in okc wrote:I bought one from harbor freight here. The same one was sold under different names. It has been great, still works great after lots of use. It is great on screws and small bits. NOT carb floats though. I've read that there are many types of fluids/cleaning agents to use for different jobs but all I've used is dish soap. Works great cleaning my reading glasses too
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
If you do a google search for "2.5 liter ultrasonic cleaner" you will find a lot that look identical. I counted 5 different labels (there are more) and prices that range from a minimum price to more than twice as much for the same cleaner. It is not big enough to submerge a complete carb in but when taken apart most of the bits can be. I have cleaned many larger parts one side at a time - just HOT water and dish soap does a pretty nice job. It was magic on the petcock strainers but destroyed all three of my carb floats.
1975 GT550
- kettle kid
- Suzuki 2-Strokes: GT380A GT750L GT750J Z900
Try this thred... the info you need is lower down, the thred..Fritz500 wrote:Any of you kind and gentle folks bought a ultrasonic cleaner. I see them advertised for $30 to $100 for small units 30W to 60W.
viewtopic.php?f=20&t=6732" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
- Fritz500
kettle kid,
Thanks for the info.
Looks like they do the job. I'll budget for one...
Geoff
Geoff
72 T500J - 95%
09 Yam XVS950A
72 T500J - 95%
09 Yam XVS950A
