tz375 wrote:That is really coming up nicely.
What do you use in your ultrasonic cleaner? Carbs never come up that cleanly in mine. I can see the wire brushed parts, but the bodies themselves look amazing.
This is the info you wanted.
Just put 4/5 caps in the 2ltr cleaner, then top up with hot tap water.
CAUTION... the water gets hot!! If you need to use the heater, Turn on for 5 mins then turn it off, and it will stay hot, I cleaned 2 carbs, then changed the water for new, and did the other one. Have a small bucket of water to rinse off, once out of the cleaner. Use some carb cleaner first on the carbs, and leave for ten mins, then use a used tooth brush to get the worst off, then spray with the carb cleaner. then put it in the cleaner. check it in 15 mins.
I think it's the dogs dangle for cleaning carbs I have had my money back already. Very happy how it came out, then used my 4" grinder, with a wire brush to clean the tops, and the inlets.Then a polishing wheel. Be lucky... KK...
Cleaner.
http://mistralie.co.uk/collections/ultr ... de-removal" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Cage for the small parts.
http://www.ebay.co.uk/itm/120746386151? ... 1439.l2649" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
