Suzuki GT500
- Country: Uk
- Suzuki 2-Strokes: Gt500 / 1976
Suzuki GT500
Hi just started my GT500 after full restoration .
Carbs were ultrasonic cleaned and new jets fitted . However it runs fine on choke , but when comes off choke it slowly dies on won’t tick over .
Also how do you get the center stand spring onto the stand ? It’s an absolute ##%##
- Country: us
- Suzuki 2-Strokes: GT
Re: Suzuki GT500
When you say new jets fitted, did you replace with mikuni jets or aftermarket? some aftermarket jets will give you trouble.
If it runs on choke but not without, it is probably a problem with idle/pilot circuit, clogged or restricted.
If I remember correctly it is easier to put the spring on when the stand is up. It is much easier if mufflers removed allowing stand to go up even more.
- Country: Uk
Re: Suzuki GT500
Thanks for info , i think they were aftermarket .....Damm . Looks like it’s carbs off again .
- Country: us
Re: Suzuki GT500
I spray carb cleaner and air through all the passages and jets to check flow, sometimes it takes me several cleanings to get clear
- Country: United States
- Suzuki 2-Strokes: t500j gt500 76 t250 71
Re: Suzuki GT500
Springs are easy,, Put one end in vise hook a piece of chain hanging to the floor. Stand on chain to stretch out spring, install washers or pennys between coils. install spring and remove washers.
- Country: Uk
Re: Suzuki GT500
Brilliant that worked so easy ......thanks
- Country: Uk
Re: Suzuki GT500
Hi ultrasonic cleaned the carbs again , put carb cleaner thro them , blew all out with compressed air and fitted all new Mikuni jets .
Bike now runs better on choke , will hold off choke for about 20 secs then starts spitting or hissing until it dies........ ideas ?
- Country: us
Re: Suzuki GT500
Is this after warmed up? Does it run ok when on throttle? my GT500A doesn't like idling until warm, I need to blip the throttle to keep running till warm.
Did you take it for a run? sometimes it helps to give it a good run.
- Country: Uk
Re: Suzuki GT500
Hi started bike this morning . Ran ok on choke , misfired on idle but ran for 5 or so minutes .
Then revs went mad......wouldn’t stop . Turned bike off , pulled spark plug caps off ......still screaming away .........turned fuel off .......still wouldn’t stop . In the end undid a spark plug and it stopped .
Spark plug was white when removed .........any help
- Evans Ward
- Suzuki 2-Strokes: 76 GT750, 72 H2 750, 84 RZ350
Re: Suzuki GT500
I’d check throttle cable routing from throttle tube to carbs including free play needed at both ends. Usually easier to do and see with fuel tank removed. Have you lubed them recently?
- Country: Uk
Re: Suzuki GT500
Yeah throttle cable ok and really free and smooth .Both ends have free play .
- Evans Ward
Re: Suzuki GT500
Carb slides in correctly and not sticking as checked with engine off?
- Country: us
Re: Suzuki GT500
Just curious how you turned the fuel off, do you have a manual shutoff?Pmd31421 wrote:turned fuel off
Sounds like it could be an air leak on intake boots or carbs.
Another way to kill is to put in gear and release clutch while holding brake, stall it.
- Country: Uk
Re: Suzuki GT500
Hi , I turned ignition and kill switch off . Pulled off spark plug caps . Disconnected petrol pipes from fuel tap so no fuel was going into carbs . It was still screaming at full revs. Never thought about sticking it in gear "..........I undid one spark plug and it stopped running
- Country: us
Re: Suzuki GT500
I would look for air leaks or partial restriction in carbs. sounds like a lean mixture issue. Float height set right ?
My GT550 ran away, that's how I know about putting in gear to stall.
