GT750 stainless steel head bolts
- Suzuki 2-Strokes: GT750
I'm installing the stainless steel head bolts and washers kit and see the original flat washers had rubber molded into them. Is it going to be a problem that the new washers don't, and if so is there a good fix?
1974 Suzuki Nomad 340
2018 Kawasaki Z900rs
- Country: WALES
Re: GT750 stainless steel head bolts
Ironically this has just been discussed on the kettle clinic
http://www.kettleclinic.co.uk/kcforum/v ... Head+bolts" onclick="window.open(this.href);return false;
98 carb Blackbird and GT550j
Well that was exceptionally helpful. Thanks.
- Country: Wales
These are what i bought.
323812452088
323812452088
You can simply put sealer bond over the washers inside and out when they are on the bolts at the heads and then torque the bolts down. Then once you are done wipe away the excess with thinners. This creates a seal to prevent water bypassing and liberal use of antiseize down inside by the shoulder and threads also helps for future removals.
