Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Wed Jan 16, 2019 1:03 am
Post new topic Reply to topic  [ 13 posts ]
Author Message
 Post subject: Part supplier
PostPosted: Mon Apr 02, 2018 8:22 am
Offline
Bikes owned: Suzuki GT550 1976
Hi just started a Restoration project on a Suzuki 1976 GT550 can anyone advise where is the best place to source replacement parts etc for this bike i am based in Chesterfield England
regards
Top
 Profile
 Post subject: Re: Part supplier
PostPosted: Mon Apr 02, 2018 11:01 am
Online
Country: WALES
Bikes owned: suzuki gt 550j
Hi i can give you a few links
https://www.discountbikespares.co.uk" onclick="window.open(this.href);return false;
https://www.robinsonsfoundry.co.uk/shop ... finder.htm" onclick="window.open(this.href);return false;
http://www.suzygtparts.com" onclick="window.open(this.href);return false;
http://www.francosmotorcycle.com/produc ... /gt-range/" onclick="window.open(this.href);return false;
Finally if you send an email to gtreiner1@aol.com he will send you a parts list
Good luck
You may want to put some photos of your bike up as a way of introduction :D
Welcome to the forum
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Mon Apr 02, 2018 5:16 pm
Offline
Bikes owned: T500R, SV1000S, TS125, Seeley T500
Also Crooks Suzuki in Barrow-in-Furness (UK's oldest Suzuki dealer)
Cheers Geoff
Top
 Profile
PostPosted: Tue Apr 03, 2018 12:38 am
Offline
Thanks for that i will send you e-mail for Parts list
i will send picture of bike before i start restoration i am aiming to have it done by Christmas no doubt you will be hearing from me in future
cheers Frogu
Top
 Profile
PostPosted: Tue Apr 03, 2018 1:10 am
Offline
World Superbike
Bikes owned: GT550s GT750 GSX1400 and lots of spares
Depends what you need. I've a garage full of GT550 parts, not far away in Barnsley.
What do you intend doing with the bike?
Top
 Profile
PostPosted: Tue Apr 03, 2018 1:52 am
Offline
Hi Just basically strip down to bear frame have that shot blasted and powder coated then rebuild replacing damaged or worn parts
the Vapour blast head etc
one thing i would like to do though is put a new wiring loom on as i have done same sort of restoration on two other bikes and alway try and put new loom/harness on but i have been looking and finding it hard to locate a New loom/Harness for the 1976 GT550
regards
Top
 Profile
PostPosted: Sat Apr 07, 2018 10:49 am
Offline
Country: England, UK
Bikes owned: FZ50, GP100, RG125 Gamma, GT380, Bandit 1200S
regards
you can buy them new genuine parts from Francos. Not cheap, but perhaps a worthwhile investment if you can afford it.
They come in several pieces. This is the front section.
https://www.ebay.co.uk/itm/SUZUKI-GT550-A-B-GT380-L-B-FRONT-WIRING-LOOM-HARNESS-36610-33103/152417552205?epid=1534544540&hash=item237ccb474d:g:QtgAAOSwJwpZ1OTS
However, this will only replace the main wiring loom and not the individual wires from existing old parts that you may be reusing, such as alternator, clocks, switch-gear etc.
On my own restoration I remade all the wiring connections from every component with new terminals soldered on. So even my old bits of wiring have good contact with practically zero resistance. I also replaced regulator and rectifier with solid state and installed an Accent ignition system (very, very easy to do and a worthwhile mod IMHO).
Good luck with your project.
Top
 Profile
PostPosted: Mon Apr 09, 2018 4:28 am
Offline
Thanks for that i will look at doing same thing
regards
Top
 Profile
PostPosted: Tue Apr 10, 2018 1:45 pm
Offline
Hi just another quick question what type of fork oil would you recommend for my 1976 GT550 i have drained the old oil and just want to be sure
regards
Top
 Profile
PostPosted: Tue Apr 10, 2018 4:06 pm
Offline
World Superbike
Depends on the ride you want. 20w50 for a more sporty ride, or 10w40 for a softer one.
Use recommended amount for the type of forks you have.
If they're solid or even too stiff, you've put too much in.
Early forks had more oil in, but they all fit the yokes - even 750 forks as they're the same diameter with heavier springs.
Top
 Profile
PostPosted: Thu Apr 12, 2018 1:37 pm
Offline
Thanks for that i will get that done and move on
one thing i am struggling with is an actual Diagrammed parts list for the actual bike 1976 GT550
the ones that only seem to be around are for GT750 & GT380
are the GT550 rare??????
regards
Top
 Profile
PostPosted: Thu Apr 12, 2018 2:59 pm
Online
Country: WALES
https://www.partzilla.com/catalog/suzuk ... indy-gt550
_________________
Top
 Profile
PostPosted: Thu Apr 12, 2018 5:09 pm
Offline
World Superbike
http://www.alpha-sports.com/suzuki_parts.htm
Pick year, model and part area. They're all on there.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 17 guests
Search for:
Jump to:
Suzuki2Strokes.com
