Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Fri Jan 18, 2019 9:30 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
 Post subject: Newbi with start up ?
PostPosted: Thu Nov 24, 2016 3:28 pm
Offline
Country: Bend, Oregon
Bikes owned: X-6 Hustler, Gs550m, Gs1000E,Gs1000C,GSF1200s
New to this site and omg, it is unreal the amount of knowledge and the incredible restoration. The number of motorcycles individuals own with such diversity from around the world, inspiring to say the least. I acquired a 1975 Gt 380 about ten years ago and finally decided to get it going. Finally acquired a set of carb and in the process of rebuilding to try to get it to run. Bike has 24k on clock, I have now idea as to how long it has sat , I have owned it about ten years myself. The question that I have is what do for the first fire up in decades, hopefully. Oil I assume is my biggest concern, should I premix first?? Thanks, so much for help. Ron
Top
 Profile
PostPosted: Fri Nov 25, 2016 10:48 am
Offline
Country: WALES
Bikes owned: suzuki gt 550j
Hi welcome to the forum. If the bike has been stood for a very long time its likely that the crank oil seals will be ruined. I presume the bike turns over okay on the kickstart? I would obviously change the gearbox oil and remove and clean the 2T oiltank fill with good quality 2t oil. Check that the oil pump works on startup by pulling on the oil cable to maximum and watch the oil being pushed along the oilpipes. There are many different theories about adding premix. Some say do, i personally wouldnt. Adding oil to the mixture that is also being pump fed may cause the cylinder to overheat as the petrol/air mixture in normal operation cools the cylinder. There are varying opinions though this is just my personal view. New plugs and points and goodluck! Let us know how it goes
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Sat Nov 26, 2016 6:21 am
Offline
I agree. If the seals are still usable, it'll probably run. Lots of people premix them for startup but I never have either. Truthfully, the Suzuki oil pumps are very reliable, and will probably work fine. If it makes you feel safer, squirt a little oil in the cylinders and kick it over a few times to coat the cylinder bores before putting any gas in it. On my first GT750, after I got a spark, I couldn't help myself, so I put a squirt of pre-mix down each plug hole and kicked it, just to hear it start. It did.
_________________
Top
 Profile
PostPosted: Tue Nov 29, 2016 11:25 am
Offline
Thanks so much for your help, will do. I assume if seals are bad it won't run? Getting closer to fire up? Is there a place to where I can find new intake boots? Will keep you informed, my pet peeve is reading a lot of posts on progress of a resto and they leave you hanging.
Top
 Profile
PostPosted: Tue Nov 29, 2016 1:05 pm
Offline
Country: WALES
The engine will run with damaged seals unless they are completely shot. There are ways to detect if they are no good but best see if it runs first i think.
Intake boots here http://www.partzilla.com/parts/search/S ... parts.html
_________________
Top
 Profile
Who is online
Users browsing this forum: No registered users and 5 guests
Search for:
Jump to:
cron
Suzuki2Strokes.com
