GT 750 restoration
- Country: United States
- Suzuki 2-Strokes: GT750, GS1000s
Re: GT 750 restoration
Looking great.
Do you have any tips for what you are using besides elbow grease to do such a nice job on the polishing you have been doing?
Thanks!
Thanks!
T700, Africa Twin, Goldwing, Super Tenere, WR250R, GS1000s, GT750, H2 750
- Suzuki 2-Strokes: T 250 +20 others
simmons1
Glad on your interests in my project. I don't know if my tips or my process of doing things will help you to much. The forks and the brake plates were in poor condition as the photos will show. Suzuki ,as well as the other m/c manuf, used to clear coat a lot of the aluminum bits. I have found that in my resto 's these parts ,after years seem to break down and corrosion takes place underneath . Marking the alum to the point ,sanding is a big time process. So what i do (right or wrong) ,i blast my parts with a fine glass bead. This will rough the alum and get rid of that wormy and sometimes patchy black marks. Then I use a 3m scouring pad -they also come in different grits- or fine steel wool to smooth things out. Then depending on what finish i want i will sand and polish with diff grades of paper. Getting a mirror finish is possible ,if you spend the time. The GT750 brake plates on the J model are pretty complicated ,so right now i will leave them and maybe polish them later.
The forks i sanded ,then used a fine scouring pad and polished them with my grinder /polisher.
Suzuki --in 72 did not spend a lot of time polishing the brake plates. When i looked at them ,the polish lines were going in 5 or 6 different directions.
Boris (bofud)
Boris (bofud)
Thank you Boris!bofud wrote:simmons1
Boris (bofud)
You have given me some great ideas for the the next time I am cleaning up Aluminum parts.
Those soda blasters you get from Harbor Freight work pretty well too and save a ton of elbow grease.
To get the failed clear-coat off, I use aircraft paint stripper. It saves tons of time.
- Country: usa
- Suzuki 2-Strokes: gt750A
I like what you are doing...it gives me inspiration to do the same to my 76 I am working on.Keep posting!
Lovely work,you must be pleased with it so far....enjoy the first outing
GT750A
GT750A
You are doing a great job. The paint is fine, and nicely done. The cylinders and head look great, not too polished. Just the way I like them.
Keep it up.
Keep it up.
I agree. I think what are you doing looks great. I am very envious of the skills people have that I don't have.
