T500 M resto
Re: T500 M resto
Do you know what 'medium' is used in vapor blasting?
- Rustygt550
Re: T500 M resto
Glass beads, water & an anti corrosion chemicalDo you know what 'medium' is used in vapor blasting?
Check out this
http://www.tsrvapourblasting.co.uk/What ... sting.html
- Scorch
- Born to ride
Re: T500 M resto
Now I need to find a place like that near Houston.
Re: T500 M resto
Nice - I understand also that some places use a slurry of baking soda and water pumped out of essentially a high pressure power washer. Either would be really messyRustygt550 wrote:Glass beads, water & an anti corrosion chemicalDo you know what 'medium' is used in vapor blasting?
Check out this
- Rustygt550
Re: T500 M resto
Well another few weeks have past, & the piston kits arrived from PM. So i have put the cylinders & heads on
I also renewed the black loom covering & replaced the conectors on the Points/Generator lead. The black loom covering is from HVC Cycle & is nice and glossy just like the Suzuki covering. I also had to replace the Blue neutral wire as it was broken in a number of places
- Rustygt550
Re: T500 M resto
It's been a few months since my last posts. Here's what I've been up to.
Got the ignition coils fitted Rechomed down pipes & flange's
- Rustygt550
Re: T500 M resto
Also got the oil lines & Pump fitted
- Rustygt550
Re: T500 M resto
Here is the bike as it sits now
- Rustygt550
Re: T500 M resto
& got the Tanks & panels painted
Re: T500 M resto
Hi Rusty,
Nice work, it is looking good .
Cheers Zunspec
Cheers Zunspec
Re: T500 M resto
WOW! Looks great. Where did you source the oil lines from?
Mike Nellis
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'04 Suzuki GSXR 1000 (racebike)
'00 Yamaha YZ426
'01 Yamaha Raptor 660
'85 Honda 250 Big Red
RV-6 Kit Airplane
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
Re: T500 M resto
Good luck with that. I've been looking for quite some time and have been unable to find anything here in the states. I found one company in Wisconsin that manufactures the equipment but they won't even return my call inquiring about the equipment.Scorch wrote:Now I need to find a place like that near Houston.
Mike Nellis
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
CMRA #23 Expert
'75 T500
'68 Honda CL350
'70 Honda CB450
'75 Honda GL1000
'00 Yamaha YZ426
RV-6 Kit Airplane
- Country: uk
- Suzuki 2-Strokes: T350 M30 T500
Re: T500 M resto
Hi There can you tell me where you got the new oillines from and regulator valves thanks
- Rustygt550
Re: T500 M resto
I got oil lines from ebay
