Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Thu Jan 23, 2020 8:50 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
PostPosted: Thu Aug 03, 2017 12:08 pm
Offline
I likes them jubblies
Country: uk
Bikes owned: tracer 700
heres some links..
https://www.discountbikespares.co.uk/ou ... ODELS.html
http://stores.ebay.com/VintageAvenueShop
_________________
Top
 Profile
PostPosted: Thu Aug 03, 2017 1:57 pm
Offline
Country: England, UK
Bikes owned: FZ50, GP100, RG125 Gamma, GT380, Bandit 1200S
great links Johnakay. Sadly none do the rubber grommet surround for the trip meter knob on my GT380. But plenty of other useful bits to find on there. Thanks
Top
 Profile
PostPosted: Fri Aug 18, 2017 4:03 am
Offline
Country: Hong Kong
Bikes owned: Kawasaki, Honda, Suzuki
Suzsmokeyallan wrote:
Please add any information to this thread for substitute parts no longer available for specific models of Suzuki. Part numbers with photos and all related information is most welcome.
Suzuki billet bar end mirrors,
Adjustable footpegs.
Racing Rearsets etc. These are the things which can be missing for specific models of suzuki.
Top
 Profile
PostPosted: Fri Aug 18, 2017 1:22 pm
Offline
Bar end mirrors are available on ebay. Rearsets, you'd have to make your own brackets or get universal ones and cobble them together to make fit.
Top
 Profile
PostPosted: Fri Oct 06, 2017 8:18 am
Offline
The rubber around the trip meter knob was never available as a separate part.
_________________
Top
 Profile WWW
PostPosted: Sat Oct 07, 2017 9:56 am
Offline
Yes it was. Part number 34192-33600
But it is no longer available.
Another part I would like is the gasket that goes around the individual dials on a GT380 set of clocks.
Part number 34181-33600
But, guess what.... No longer available!
Top
 Profile
PostPosted: Sat Nov 25, 2017 6:44 am
Offline
Country: england
Bikes owned: several gt250 ramairs
a lot of stuff on here, including repro carb rubbers [top and bottom] for the 380 and 550. i've had some and they don't turn to goo after a few months. also a lot cheaper than the genuine ones, which do turn to goo :D
http://www.classicsuzukiparts.nl/2strokemenu/?lang=en
_________________
Top
 Profile
PostPosted: Sat Nov 25, 2017 1:15 pm
Offline
http://www.classicsuzukiparts.nl/2strokemenu/?lang=en" onclick="window.open(this.href);return false;
Hmm. I'll have to get in touch with them. I fancy a set of carb rubbers if they are not too pricey.
Top
 Profile
PostPosted: Sat Nov 25, 2017 1:31 pm
Offline
Country: WALES
Bikes owned: suzuki gt 550j
Its worth remembering its important the carb rubbers have to be supple to flex and provide an airtight seal or air gets in and weakens the mixture. Also remember NOS means the rubber is probably 40 years old ! So modern repro as long as its quality made is better.
_________________
98 carb Blackbird and GT550j
Top
 Profile
PostPosted: Sat Nov 25, 2017 1:42 pm
Offline
Country: england
it's actually the bellows type rubbers that go on the top and the bottom of the carb doohicky :D i had 2 sets some years ago [about 5] and they are still fine - no goo :D
_________________
Top
 Profile
PostPosted: Fri Dec 01, 2017 7:00 pm
Offline
Are we talking about the same item? the trip knob rubber for the GT250 380 500 and 550 from 72 to 77 was never available as a separate part. Only the knob and screw was available.
_________________
Top
 Profile WWW
PostPosted: Mon Dec 04, 2017 1:05 pm
Offline
Yes, we are talking about the same part. I have seen it in a parts diagram and checked the part number on robinsons foundry. I even saw it for sale a long time ago. I just wish I had bought one then while it was still available. :(
Top
 Profile
PostPosted: Sat Dec 09, 2017 5:34 pm
Offline
The oem parts diagrams don't even show it in the photo of the gauges. As a matter of fact I have never seen the trip knob boots available as a separate part for any of the GT gauges.
_________________
Top
 Profile WWW
PostPosted: Sun Dec 10, 2017 1:50 pm
Offline
Component number 15, which is part number 34192-33600
I would also like 34181-33600 which is number 14 in the picture but that is not available too.
Top
 Profile
PostPosted: Sun Dec 24, 2017 4:37 pm
Offline
http://www.claussstudios.com/id47.html
Lots of rubber parts.
wiseco.com will make any pistons so long as you order 12 of them
I make the rubber grommets used on the front of the gas tanks of the T20 and similar that are bolted to the frame and do not slide into the rubber buttons on the inside of the tank. They also work well for the back of the tank on the T305/TC305/T350/T500 where it bolts down to the frame.
Given a reasonable used part, I can replicate most plastic or rubber parts in polyurethane. I have done RE5 headlight buckets for Jess at Rotary Recycle.
I do swingarm bushings in Steel & Aluminum Bronze too.
For the T250/T305/TC305/T350/T500, the instrument bulb harnesses with the over-molded rubber plugs that hold them into the speedo and tach are no longer available. I make Delrin plugs that replace the rubber parts that crumble away. It is impractical to mold new ones onto the used harnesses, so this is a simple fix...just break off the dried out rubber, bead-blast the sockets for good electrical contact, and use the plastic plugs instead.
_________________
SKA125 (1962)
M15
T10 (2x one with Hyd rear brake)
S32-2 (2x)
T20 (2x)
T200
TC250 (3x)
TC305
T305
T350
T500 (5x)
GT185
GT550
GT750 (2x)
RE5 (3x)
TS50
TC125 (2x)
TS125 (2x)
TS185
TS250 (1970)
TS250 (3x)
TM250
RL250
TS400 (2x)
TM400 (2x)
B-King
Top
 Profile
Who is online
Users browsing this forum: No registered users and 57 guests
Search for:
Jump to:
Suzuki2Strokes.com
