Are the 750/550/380 throttle tubes the same degree ?
- Country: U.S.
Does anyone know for sure if the 750/550/380 have the same throttle degree turn ? I'm pretty confident that the degree of turn for example is 1/6th on the 550 and perhaps the 750 also. Are the throttle tubes on all three models the same degree turn ?
Re: Are the 750/550/380 throttle tubes the same degree ?
Interesting question! Yes for 380 and 550, because the throttle tube part numbers are the same. 750 part number is different but whether that affects degrees I have no idea.
Cheers, Mike
Cheers, Mike
