Compression test fun
My 380 developed a small leak from the head gasket of the centre cylinder, with oily smears visible. It's because of a loose head stud, which I'll fix over winter.
However, it's still running great and hasn't lost any performance. So just for fun I did a compression test after a ride at the weekend. Left: 132psi Centre: 135psi Right: 134psi.
It goes to show something, I'm not sure what that is, however :wth: :wink: :D
Re: Compression test fun
Back in the early 80s, I was always cracking heads on my 500s, and like you, I would end up with oil misting all over the place....but the bike still went well, with no detectable loss of performance.
Are the 500s prone to cracking heads? Where on the heads do they crack?
Lots of great 500 info here http://www.ozebook.com/compendium/t500index.htm" onclick="window.open(this.href);return false;
ja-moo
Post by ja-moo »
The speed of the combustion cycles is just milliseconds, and the area of a crack so miniscule, you won't see any difference in compression, until it's in 2 pieces, then you will see a big drop...... :wink:
