Glad you figured it out Chris. I have been reading this as it went along, waiting for an answer in case it comes up with mine.
Kevin
carburetor woes -- GT550
- My new bike is "IRIS"
Chris,
Glad to hear you figured it out. I can't tell you how often it turns out to be things you absolutely positively know that it cannot be.
Rack mounted carbs often have wear in the pivots and adjusting nuts that make it difficult to get them to open together and to close together. In your case, it sounds more fundamental -and now it's fixed. great result.
- H2RICK
- Country: CANADA
So much for my carb syncro guyCode: Select all
Glad you got it sorted out, Chris. From the above quote I guess you'll be doing this kind of thing yourself from now on....... :wink:
GT550A Mint & Original
MBD Sufferer
MBD Sufferer
I did it the first time. I took it to him to see if he could vacuum balance them. All he did was severly screw them up. I'm surprised it ran at all. No wonder the thing wouldn't idle down. I'm not even sure now that the jets were in fault. Regardless, the carbs are sporting 1 overs now. Air screws are right where they belong now too. 1 1/2 turn out.
