Suzuki2Strokes.com
Sundial Moto Sports
Suzuki2Strokes.com
It is currently Sun Sep 23, 2018 7:17 am
Post new topic Reply to topic  [ 38 posts ]  Go to page 1, 2, 3  Next
Author Message
 Post subject: T500 Electronic Ignition
PostPosted: Sat Apr 21, 2012 9:01 pm
Offline
Does anyone have a recommendation for electronic ignition for 1970 T500 Suzuki. Thanks
_________________
1970 Suzuki T500 Titan Twin
1971 Yamaha HS1B 90cc Twin
Top
 Profile
PostPosted: Sun Apr 22, 2012 6:18 am
Offline
Newtronics makes one... http://www.newtronic.co.uk/newtronic/
I have used them on my GT750,GT550..... GT750 has over 50K trouble free miles on the ignition..
Top
 Profile
PostPosted: Sun Apr 22, 2012 6:46 am
Offline
Am also a fan of the Newtronic ignition system, but they don't currently make one for the T500.
Several choices are listed under this topic: http://www.suzuki2strokes.com/forum/viewtopic.php?f=29&t=4824
Two options for the T500 are:
Marel's: http://www.suzukitandgtparts.nl/hotpartsen.htm
Powerdynamo: http://www.powerdynamo.biz/eng/systems/7261/7261main.htm
Powerdynamo is more expensive but the T500 kit also includes a higher-output alternator.
_________________
GT550 72 project & 75
T500 73 project
T350 69, 71 & 72 project
T250 72
Top
 Profile
PostPosted: Sun Apr 22, 2012 7:26 pm
Offline
Bikes owned: M50 T250 T350 T500
I purchased a Newtronics system for my T500 here in Oz a few months ago. Had to swap the sensors around on the backing plate as they were installed incorrectly but after that the bike has run like a dream.
Top
 Profile
PostPosted: Mon Apr 23, 2012 1:32 pm
Offline
Was under the impression that the Newtronic system for the T500 was no longer available.
The company's website doesn't list the SU7 kit for the T500. But it also doesn't list separate kits for the GT750/GT380 & GT550.
http://www.newtronic.co.uk/newtronic/system/index.html
HVCcycle, the US retailer for Newtronic no longer sells them.
http://www.hvccycle.com/ignition-newtronic.html
An Austrailian retailer lists the T500 kit as well as separate kits for the GT750/GT380 & GT550. Don't know if the T500 kit is old stock or new.
http://www.motorcycle-ignition.com.au/motorcycle_ei_kit.htm
Oilburner, was the T500 backing plate metal or circuit board material? Was the kit labeled SU7 for the T500?
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Mon Apr 23, 2012 5:17 pm
Offline
The backing plate is metal. I can look at the packing box and get the model number tonight.
Top
 Profile
PostPosted: Mon Apr 23, 2012 10:48 pm
Offline
How hard would it be to modify the points backing plate to take a DYNA S system?
Top
 Profile
PostPosted: Mon Apr 23, 2012 11:03 pm
Offline
I have a friend that races a honda 500/4 sidecar and he is on his third dyna ignition system. i had a look at the failed units and could see that the encapsulation had lumps in it that indicated something had burnt out. Personally i would go with the Newtronics.
Top
 Profile
PostPosted: Tue Apr 24, 2012 7:22 am
Offline
Looks like Newtronic might be making the T500 kits again. Of what I've seen, older Newtronic kits use circuit board material for the backing plates, & updated/new kits use metal backing plates.
Newtronic would probably sell a lot more kits if they made it easier to order. Their website directs you to eBay & they don't list all their kits there. The US retailer (HVCcycle) stopped selling them.
Anyone know of Newtronic retailers other than the Austrailian company (motorcycle-ignition.com)?
A suggestion for the Honda 500/4 racer & anyone else going with modern ignition systems...
Upgrade to a modern voltage regulator or modern rectifier/regulator -- they control voltage much better than vintage voltage regulators.
Some vintage bikes, like the T250 & T350, don't even have voltage regulators.
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Tue Nov 20, 2012 10:20 am
Offline
I meant to share this information some time back, so here we go..
The Newtronic SU7 Kit is available, you have to call the guy and ask him to make you one. They don't advertise it because the kit is not ready to go! You have to do a slight modification.
The first thing you do is drill out the sensor eye plates, so that they can be adjusted back and forth to get your timing correct on the fire. The second modification you need is the shown below. I had these "washers" machined from steel bar - you drop one under the Newtronic Rotor, so that the arm will pass through the sensor eyes without hitting them. Works like a charm. Bike never ran better.
I have a couple of extra washer mods if you want one. $10.00 each, to help cover my post and shipping.
http://www.newtronic.co.uk/newtronic/system/index.html" onclick="window.open(this.href);return false;
_________________
Top
 Profile
PostPosted: Wed Nov 21, 2012 8:31 am
Offline
Bikes owned: 74 GT550
This place dosen't look like it currently has the T500 kit. They do list all the GT series bikes at what seems to be a reasonable price. I am contemplating ordering the gt500 kit for my bike. Anyone have any experience with this company?
http://www.thunderroadbikes.com/newtron ... suzuki.htm
_________________
1974 Suzuki GT550
1983 Honda XL250
2002 Yamaha Bear Tracker
1959 Lone Star Malibu
Top
 Profile
PostPosted: Wed Nov 21, 2012 9:47 am
Offline
LexPaul, for future reference by forum members would help if you provide:
1) a sketch with dimension of your "washers"
2) a sketch or pic showing how you drilled out the sensor plates.
Did you also upgrade to a modern regulator/rectifier?
_________________
T500 73 project
T250 72
Top
 Profile
PostPosted: Wed Nov 21, 2012 10:44 am
Offline
Lex,
I would be interested in two of the washers - I have a SU7 kit and an SU2 which was for the T250 but physically the same as the SU7. Please PM me with your info.
Also, you may want to consider having the stator rewound to provide more watts which will allow you in turn to upgrade to a higher watt headlamp bulb. There's a shop in Colorado that does this:
Mayers Motorcycle Electrical Service
77 Hoosier Ct
Nederland, CO 80466
303-258-0213
Kevin Mayer
kevin777motorcycles AT yahoo DOT com
I think they used to charge about $185 to do this which is still cheaper than a powderdymo system particularly since you've already got the Newtronics in and working...
Jim
Top
 Profile
PostPosted: Fri Nov 23, 2012 3:40 pm
Offline
Bikes owned: T500, TR500, T20, TS250, B105P, GS250T
I've run the Newtronic on my TR500 race baike for 8 seasons and have had no trouble with it. It was originally a kit for the GT250 so I had to modify a few things as related above. Once set, you never have to fiddle with adjusting again.
_________________
Ralph Spencer
Shoemaker Vintage Moto LLC
Southfield, MI USA
www.shoemakervintage.com
AHRMA #798
Top
 Profile WWW
PostPosted: Tue Nov 27, 2012 12:34 pm
Offline
I'm running the German-Czech Power-Dynamo system.
I'm definitely bent out of shape due to the fact that the rotor was not properly marked with a timing mark, but after getting it set up, everything appears to be working fantastically. I'll update with another message when I have more miles on it.
_________________
1969 T-500-II Candy Gold
1969 T-500-II Project Roller
Top
 Profile WWW
Who is online
Users browsing this forum: dollydog and 47 guests
Search for:
Jump to:
cron
Suzuki2Strokes.com
