I'm trying to get one of my T20's (X6 Hustler) running. I pulled the carbs yesterday and they were really varnished up, but they cleaned up really well. One of the floats has a really small dent in both bulbs of the float. Is this likely to cause a problem?
Wayne
t20 Carb Float ?
- Suzuki 2-Strokes: 1976 GT750
t20 Carb Float ?
No Wayne it will still float the same way but look funny. Ive had good success removing float dents on the sides by placing some contact cement on the spot with a matchstick, pull on the stick or sticks when it cures and usually the dent comes out.
Then drop the float into some thinners and the cement comes of quite easily.
For bigger AND uglier dents in the sides, drill a tiny hole in the seam and blow compressed air into the hole to push the dents back out, then resolder the hole.
