Suzuki fuel taps
phil-woody
Country: uk
Suzuki 2-Strokes: Suzuki 600 bandit,gt500a,dunstall gt500a
Suzuki fuel taps
Post by phil-woody »
Hi all ,
Does anybody know if there is anybody supplying reproduction fuel taps for a Suzuki GT 500 , as ive been told that original ones are obsolete .
Regards Woody .
Jughead
This IS the real me!!!
Re: Suzuki fuel taps
Post by Jughead »
Woody you may try to adapt a pingle if you can't find an original.you'll just have to remember to shut off the fuel when you park it since it isn't vaccum operated.
Hang me from the Tree of Shame.Damn! I forgot the Rope.
Used taps are not rare.....could you not refurb one?
And a different question - what's wrong with the old one ?
Jughead
Post by Jughead »
On a Used Original petcock with a Bad Diaphram you can make a solid gasket out of gasket material to replace the Diaphram and then crimp off the tall tube that goes into the tank.just run your petcock on Reserve and use on as the New off.I done mine this way since I am running aftermarket mikunis.
The GT500 & GT750 use the same o-ring for attaching the petcock to the tank. Its part # 44348-31051.
Looks likely that a GT750M-A petcock will work. Its still available for around $100.
Perhaps another forum member can confirm this?
Pingel also sells vacuum petcocks. Have one on my GT250.
It attaches to the older style T250/T350/T500/GT250 tanks without an adapter.
They sell adapters but I wouldn't know which one to use for the GT500.
GT500 petcock: http://www.suzukipartshouse.com/#/Suzuki/GT500_(1976" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;)/FUEL_COCK/021140001/56021140025
GT750 petcock: http://www.suzukipartshouse.com/#/Suzuki/GT750_(1975" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;)/FUEL_COCK/021180003/56021180048
phil-woody
Country: uk
Hi chaps .
Thanks for the replys , im after another fuel tap for another tank ive got that hasnt got one fitted to it .
two-stroke-brit
Suzuki 2-Strokes: gt750
Post by two-stroke-brit »
phil-woody wrote:Hi chaps .
hi phill i have a decent one for sale,
i will pm you tonite with a pic.
cheers mark
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
husky99
Suzuki 2-Strokes: 1972 GT 380, Harley FLHK
Post by husky99 »
Jughead wrote:On a Used Original petcock with a Bad Diaphram you can make a solid gasket out of gasket material to replace the Diaphram and then crimp off the tall tube that goes into the tank.just run your petcock on Reserve and use on as the New off.I done mine this way since I am running aftermarket mikunis.
GREAT IDEA!
Jughead, Where you been?. You didn't fall off the face of the earth --- or worse, get married?
advant63
Country: canada
Suzuki 2-Strokes: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
Post by advant63 »
reproduction decals has 22mm petcocks. 44$.
http://www.reproductiondecals.com/" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
