Did I ruin my new battery?
Got a new battery for the GS1000 this morning. Added the electrolyte, waited 1.5 hrs. and topped it up. On the charger it went. I checked it at 12.54 volts. Went back 2 hours later - still at 12.54. Waited another hour and checked again. 12.54. Then I noticed (like an idiot) I had the leads reversed. Corrected that and waited another hour. Still at 12.54. Nothing got hot, the charger and battery remained cool. Low amp charger, about 1/2 amp. Did I toast my $40.09 brand new battery?
Re: Did I ruin my new battery?
Good news. it's at 12.94 byy one meter and 13.07 on my newer meter.
gyrocfi
Post by gyrocfi »
Most chargers have a safety circuit that will open if polarity is reversed. got lucky!
77' RD400 Stock
77' RD400 work in progess
76' Suzuki GT500A Titan 2 of 'em
76' RD400 frame, 79' rd400 Daytona bottom 77' top, 75' rd350 wire wheels, Factory products pipes
96' Honda PC800 for towing my RDs
Battery is in and working great. I checked the charging system - also working good. About 12.6 volts at idle up to 14.1 at higher rpms. It's a smooth curve as the rpms rise.
When I bought the bike in 95, it had a fried voltage regulator. The PO had wired around it and the bike was running on a constant loss. Not a good idea as these things MUST have a hot battery to run. I guess that's why they didn't put any provision for a kicker. If the battery is dead or near dead, you ain't going nowhere pal, and all the kicking in the world won't start it.
