Just acquired a 4LS GT550 with J&R Power Pipes expansion chambers.
As shown in the pic, the pipes have a disk welded on the end. There are no removable baffles. Is this setup the way Power Pipes were made? Did they come with removable baffles that are now missing?
J&R Power Pipes on GT550
- Cliff
Re: J&R Power Pipes on GT550
Don't know about the pipes other than that is not a very good looking weld!
I do see that you need rear brakes, a new chain and tire!
No and yes. They came with removable baffles and those have been modified - maybe they lost the circlip or perhaps the circlip groove was worn out or too large.
+1 to what TZ375 said, you can see the old circlip groove.
That square-section tyre is amazing
Thanks for the info.
Haven't ridden the bike yet. Had it running - exhaust pressure pulses felt uniform & trace of smoke was uniform as well.
Currently has a vintage Bates fairing. If the bike works out, will probably go with a nickel-plated Omar/Jemco 3-into-1 exhaust & remove the fairing.
Don't know what the manufacturers were thinking when they made square-section bike tires like the one in the pic.
- Cliff
This is what happens with a square section rear tire!!
http://www.photoreflect.com/store/Order ... o=14&pc=24" onclick="window.open(this.href);return false;
Agreed. Looking at images 9--11, that looks like a car tire.
Have Avon RoadRiders on several on my bikes. Probably will use them on the GT550 too.
