looking for the tsb air jets
keystoker
Post by keystoker »
hello everybody i am trying to do the tsb on the surging. i called suzuki with the part numbers from the tsb and they say the jets are unavaliable. does anybody know where i can get 3 .8mm air jets for my 1975gt750
thanks chris
diamondj
Re: looking for the tsb air jets
Post by diamondj »
The 0.9mm air jet shows as available still:
http://www.ronayers.com" onclick="window.open(this.href);return false;
part number 09493-18001
JET PILOT AIR 0
JET PILOT AIR 0
Mfg. Part Number: 09493-18001
SKU: 98253
MSRP: $10.21
Your Price: $8.46
You can order them on-line from Ron Ayers.
Often for parts on older Suzukis, if you don't want to buy them on-line then you are much better off going to the local dealership and feeding them the part numbers without telling them what they are for. For some reason all the parts counter guys seemed to be trained to assume if it's more than a couple of years old, the parts are NLA which is NOT always the case.
Jim
Or you call your local Mikuni supplier and as for three AIR JETS. BS30/97 size #90 as shown on http://pinkpossum.com/GT750/carb/BS40carbs.htm" onclick="window.open(this.href);return false;.
Get them here http://www.accu-products.com/mikuni/jets/cat_45.html" onclick="window.open(this.href);return false; for less than 4 bucks each.
or here http://cgi.ebay.com/ebaymotors/Mikuni-A ... 0540716076" onclick="window.open(this.href);return false;
They are listed at 12bucks in NZ and around 7 to 8 in some online stores. I'd go to Accu-products.
