1975 Suzuki Gt550 Fuel Coming Out around the left cylinder.
Posted: Thu Jun 30, 2011 12:54 pm
by kadavenport
I bought a 1975 GT550 about a month ago. Thus far I have really just been putting around on the bike, cleaning and polishing. To my knowledge it is completely stock, with the exception of unifilters in the stock airbox. It starts easy, but leaks a good bit of fuel (Gas and Oil) out of the left cylinder (my left if I'm on the bike). The bike smokes little to none after it warms up and I take off the choke. Its really only noticeable if the bike has sat for a couple of days. What could be causing this and am I going to harm the bike by riding it with this leak? Thanks in advance for the advice!
Kyle D.
Re: 1975 Suzuki Gt550 Fuel Coming Out around the left cylind
Posted: Thu Jun 30, 2011 1:40 pm
by Cliff
Where is the leak? Under the head or at the base?
Posted: Thu Jun 30, 2011 1:52 pm
by kadavenport
Around the exhaust as far as I can tell, but possible a lil under the head. No leaks at all from the base.
Kyle D.
Posted: Thu Jun 30, 2011 2:47 pm
by Coyote
Get some new exhaust gaskets. Smear a little high temp RTV on both sides of the gasket at re assembly
Posted: Thu Jun 30, 2011 2:51 pm
by oldjapanesebikes
+1 to Coyote's comment - likely just a leaking exhaust gasket - fairly common problem, and leaks oily crud all over your leg. You might try tightening it up slightly to see if it makes a difference before trying the RTV. I'd also suggest pulling the baffle in the pipe just to check that it isn't plugged up, as that can also cause exhaust flange leakage.
Posted: Thu Jun 30, 2011 3:55 pm
by kadavenport
Thanks for the advice guys. Heading to the garage now.
Posted: Sat Jul 02, 2011 2:32 pm
by kadavenport
Retightened all the exhaust to spec. No leaks, thanks guys.
Posted: Sat Jul 02, 2011 6:35 pm
by Cliff
You're Welcome!
