I may be dealing with separate issues here, so here are a few more details:
First, when the bike started running rough at idle I switched off the headlight and *thought* it improved. The neutral light was barely visible by the time I got back, so unless my eyes were playing tricks on me I'm thinking it's a problem with the charging system. It still accelerated well with moderate to heavy throttle. I'll have to get my volt meter out tomorrow to see.
Second, and what really concerns me, is why the oil level ROSE and TURNED WHITE AGAIN. I filled the crankcase by measuring out 2200 cc, but when I got back it was clearly over-filled. I'm praying it's not asking for a major overhaul! So I have two questions: first, is it possible it's the o-rings in the waterpump assembly? I didn't have a tach cable when I started this project, so I didn't realize the nylon water pump gear was toothless for the first few times I ran it. I don't think I would have overheated it just running it on the center-stand but have no way to say for sure. There are no leaks visible around the water pump cover. My second question is whether a cylinder leak down test would be a good way to find out where the problem is? Thanks for the help!
