fiberglass fuel tank mounts
Posted: Tue Mar 08, 2011 4:15 pm
by joewillybob
I have a fiberglass seat and tank that was a dealer installed option an early t20's. I'm installing them on a T350 cafe project. The front of the tank is held down with a rubber strap similar to the strap that holds the poly oil tank. Anyone have any ideas where I might find one or something similar? Thanks.
Re: fiberglass fuel tank mounts
Posted: Tue Mar 08, 2011 5:47 pm
by ja-moo
joewillybob wrote:I have a fiberglass seat and tank that was a dealer installed option an early t20's. I'm installing them on a T350 cafe project. The front of the tank is held down with a rubber strap similar to the strap that holds the poly oil tank. Anyone have any ideas where I might find one or something similar? Thanks.
I'm looking for some also, but the main thing is if you are using street gas, and there is any ethanol, you will need to coat the tank with Caswell 2 part tank coating, or it will eat the resin and goop everything up. Don't scrimp, use the full quart, even though most will drain out, a pint will not cover a tank, it's too thick......
Posted: Wed Mar 09, 2011 12:37 pm
by joewillybob
thanks for the tip. already have the caswell sealer,just haven't used it yet.
