TR750 WATER PUMP DRIVE
Posted: Wed Dec 22, 2010 8:56 am
by kekems
Hi evrybody ,
i am new on this forum
i start to build a Tr750 replica and collecting info's and pics i have obviously more questions than answers
i remarked on works engine pics that the waterpump driving system is quite different compared to the stock.
it seems that the starter gear crank side is running a new all metal water pump gear.
on a ratio close to 1to1
Does anybody has kwowledge about that ?
Marc
Re: TR750 WATER PUMP DRIVE
Posted: Wed Dec 22, 2010 9:39 am
TR750 had the two crank ends on the opposite sides. The old Alternator end is moved to the left to drive the self generating ignition and the old points/pump drive side is moved to the right side and machined off.
So it used a different steel gear to drive the water pump. I have seen pictures of a TR motor with s GT nylon gear and with a steel gear, but in both cases the gear on the crank is a unique TR part which fits behind the ignition rotor.
Barton motors used a short drive shaft with its own gear and that drove the Krober ignition in a new left cover.
I'd like to see a parts list for a TR750
Posted: Wed Dec 22, 2010 4:50 pm
by kekems
thanks TZ
i assume i will have to deal with the stock system that i will lightend a lot as i have seen on this forum.
i intend to switch ignition on the right side while using the gearing layout of the waterpump on the left side.
is this possible without switching the crank ends?
Posted: Wed Dec 22, 2010 10:23 pm
If you use a light system such as say a fully programmable Ignitech, it could go on either end. If you fit say an HPI or electrexworld self generating system it's designed to fit on the right side with a stock crank right end I think.
