buffalo swinger bushings
Posted: Thu Dec 09, 2010 7:31 pm
by two-stroke-brit
does anyone have the dims for the bushings in the buffalo swinger as i cant seem find a suplier, i may as well make some up myself.
i can measure the parts when i dissasemble the swinger but it would save me some down time if i have them ready to instal.
iam looking to replace them with bronze ones.
thanks mark
Re: buffalo swinger bushings
Posted: Thu Dec 09, 2010 9:17 pm
by Suzsmokeyallan
Mark, Richard TZ375 has a needle bearing conversion worth looking into, thats much better than any bushing for sure.
Posted: Thu Dec 09, 2010 10:59 pm
by H2RICK
If you want to go with the bronze bushings, Parts N More has 'em.
Most back street shops can get them for you. Zook-e at Sundial maybe even has a set in stock if you PM him.
Posted: Fri Dec 10, 2010 3:31 pm
by rbond
Check with oldjapanesebikes for a conversion primer, he has a great tutorial on the needle bearings.
Posted: Fri Dec 10, 2010 4:09 pm
by two-stroke-brit
H2RICK wrote:If you want to go with the bronze bushings, Parts N More has 'em.
parts and more dont carry them any more but thanks.
mark
Posted: Fri Dec 10, 2010 5:47 pm
by oldjapanesebikes
Lots of options - there is the needle bearing conversion Richard developed - all I did was write about it and install it on one bike, the UK Kettle Club still sells a pair of bronze ones with the driver to install them - just drop them am email if that is the way you want to go. Expensive though. Of course you can just re-install the original fibre style which are still available from your friendly Suzuki dealer for about $9 each side 8)
Posted: Sat Dec 11, 2010 12:03 am
by markj
I did the needle bearing conversion and while I haven't road tested it yet it appears to be a good, easy mod. It's got to be better than the fiber bushings.
Posted: Thu Jan 06, 2011 7:54 pm
by H2RICK
UPDATE:
I spoke to my supplier of the bronze swingarm bushings today and he has NINE...count 'em....NINE sets in stock. These fit a variety of old Suzis including the Buffalo and the 550 amongst others.
Sooooo.....if anyone is stuck for a set just PM me and I'll get 'em for you. I think the retail is something like $65.00 per set (no taxes applicable at my end if you're an outside-of-Canada customer).....plus postage of course....which wouldn't be too terribly much to the US for something that small. Heck, it probably wouldn't be that expensive to the UK, even.
Posted: Fri Jan 07, 2011 1:56 pm
by two-stroke-brit
thanks for doing that rick ,i have got some of the fibre bushes and i have measured them up and will make some oilite replacements in the near future.i also fitted up some new rubber to the lester mags i got and i think i will go ahead and change out the stock swinger for the ali gs1100 one .
thanks again mark.
Posted: Sat Jan 08, 2011 8:05 am
by Coyote
Hey Mark. Oilite (sintered bronze) is a good choice. Wayyyy better than plain bronze. Another good choice would be nylatron (oil impregnated nylon). That stuff NEVER wears out, and it machines great with old school high speed steel tooling. Never another worry about lube.
Machine it dry (no coolant) to about +.003 both ID and OD. Assemble it and forget it!.
