Will GT380 headlight ears and headlight assembly work on a GT550? I ask because I bought a set on Ebay, but they're definitely for a 380 and not my 550. I want to know if I have to send them back.
Thanks,
Joe
Headlight ears
Headlight ears
1974 Suzuki GT550 - Smoke Generator
2010 Harley-Davidson FXDB - The Commuter
1994 Honda Nighthawk 250 - Almost Run Over
- advant63
- Country: canada
- Suzuki 2-Strokes: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
Re: Headlight ears
joe, would you be interested in a trade?
i have a set of 550 ears and need a set of gt250/380 ears.
if so i will email photos of what i have.
p.m. me.
dennis
p.m. me.
dennis
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
s32-2 s32-2 t250r
gt250 t500r gt550a
Re: Headlight ears
The 380 forks are smaller, @33mm dia. The 550 being 35mm. The 380 also has a smaller headlight than the 550, which has the same one as the 750. The 380 ears also have the signal mount stub built in, accommodating different signals than the 550, or 750. The earlier ones did have the mount hole for GT signals, but the part numbers are different, so they are not interchangeable, most likely due to the fork diameter difference. Hope this helps a bit. Cheers.
Fred
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
Ducati 750 GTs
Suzuki RE5s
Re: Headlight ears
Thanks! If I can work out a trade with the previous reply, so be it, otherwise they go back to the guy on Ebay as he said they were 550 ears.
- wvc
Re: Headlight ears
if you don't trade, I'm interested in buying them from you. Sent you a PM.
4 other 76 GT500's
1.5 GT550's
4 GT380's
5 T500's (72-75 models)
4 GT750's
4 other 76 GT500's
1.5 GT550's
4 GT380's
4 GT750's
