gt750 Cable Routing Pictures
demozg1000
Post by demozg1000 »
I am trying to put my 76 gt750 back together and having a devil of a time getting the cables routed correctly. Does anybody have pictures of the cable routing under the tank? I am espically having issuse with the throttle binding. thanks
Re: gt750 Cable Routing Pictures
Try this,
viewtopic.php?f=8&t=3201" onclick="window.open(this.href);return false;"
The tach cable goes on the left side of the steering stem and along the horizontal frame rail and down to the cover, the clutch cable and throttle cables go on the right side of the steering stem and generally flow in a smooth unrestricted route along the same frame rail with no sharp bends etc.
The wiring diagram pics at the guide generally shows the way they run with the wiring harness.
demozg1000
I actually have that page book marked. Its a great guide. The only thing I dont see is the throttles. Do they go under the coils or along side the frame? I really could use a side view. thanks again
demozg1000 wrote:I actually have that page book marked. Its a great guide. The only thing I dont see is the throttles. Do they go under the coils or along side the frame? I really could use a side view. thanks again
I've made a note to add this in the next edition :D if I can locate a good original to photograph. 8)
demozg1000
oldjapanesebikes your site rocks!! I have used your restoration pages a a reference. It was a real help.Thanks
Image Image Image
demozg1000
Suzuki Dave YOU ROCK!! Thank you very much. you made my night.
Demozg1000
