Hi all, I have removed the carbs from the J tonight for complete strip and clean. I did this by making loose all bands and the top two air box screws, I was able then to man handle the tubes off the back of the carbs and have then sit under the carbs, but still not able to remove the air box, I then removed the left carb and was then able to extract the air box with the 3/boot rubber without too much hassle.
Is there a best way to reinstall everything? , I was thinking the reverse, install the right and centre carbs, then the air box with 3 boot rubber in place over the carb backs and last the left carb.
Any other suggestions.... thanks.
GT750J carb install
GT750J carb install
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
- Novice racer
- Suzuki 2-Strokes: gt750
Re: GT750J carb install
hi chris i find it easiest to put the air box on, then the center carb, then the boot and then the outside carbs, but its a struggle anyway way around.
cheers mark.
cheers mark.
1973 SUZUKI GT750K.=SOLD
1982 HONDA CB900F =SOLD
1982 YAMAHA RD350LC.
1985 RZ350N
1985 RZ350N
