turn signal flasher
rbond
turn signal flasher
Post by rbond »
Does anyone know of a replacement flasher for GT750,550,500,etc. OEM part# 38610-32210. The cheapest I have seen is $48.00. Again I can't see the high price for this, an after market for a car is $3.00. Guess I will have to open the old one up and see if I can reverse engineer this too. This is nuts to go to this much trouble for the simplest of things. :x :x
advant63
Country: canada
Suzuki 2-Strokes: m12 or50 a100 s32-2 s32-2 t250 gt250 t500r
Re: turn signal flasher
Post by advant63 »
any two prong flasher unit will do. i replace mine with these.
http://www.princessauto.com/truck/truck ... it-flasher
they are smaller than stock(loose in the holder). you could probably fit it inside the stock housing if you're worried about appearance.
m12 or50 k10 a100
s32-2 s32-2 t250r
gt250 t500r gt550a
twin cobras in baskets
Open you old one up and see if the contacts need cleaning and drawing in a tad, thats usually the problem.
I bought a small electronic one form Autoparts and it seems to work fine with old style bulbs, LEDS or just the fronts and no rears - any combo and the cost was about 10 bucks IIRC.
rbond
Post by rbond »
I bought a two terminal electronic flasher from Oreilly's Auto parts for $9.79. Works perfectly.
That's quite a saving over OEM prices. Problem solved cheaply. Gotta love it.
