Looking to remove the 4LS Drum from the the old forks, how do I loosen/remove the bolts from the torque bars with those brackets o them?
4LS Torque Bolt removal?
Re: 4LS Torque Bolt removal?
The tabs against the bolts are meant to be bent down. Then when you put the bolt back in, you bend the tabs back against the bolt. This keeps the bolt from backing out when the bike is together.
Jim
Jim
Ah, bent down, thats the trick.
Thanks!
Thanks!
