T500 steering stem bearings
Anyone know where I can get tapered bearing sets for t500, and is there other adjustments needed to fit them?
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
Re: T500 steering stem bearings
Hi found an old topic on this forum dated 2008 about this thread, 3 pages of this and that, surely it can't be that hard, can it? , anyway one of the posts mentioned allballs and I have that catalogue here, GT500 bearings are available, so is the GT500 set up the same as T500, anyone know?
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
Chris,
Debbie resolved the tapered stem bearing issue some time ago:
viewtopic.php?f=2&t=614&p=78307&hilit=t ... ngs#p78307" onclick="window.open(this.href);return false;
The GT bearing sets WON'T fit as the lower bearing has an ID of 27 MM and all the T series bikes have a 30 MM lip for the lower bearing.
The Kawasaki H1/H2 bearings will work as a set for the T-500.
Jim
Jim
thanks for that Jim, the KH500 bearing set is also listed in the All Balls catelogue, I'll get a set next week and give them a shot. I'll still fit the damper but of course it will just be for show now.
BTW the lower shoulder is removable, it is basically a tight fit sleeve, if you apply heat with a flame like oxy or gas gun it will almost fall off. I may actually do that and fit a full width sleeve so it matches the height of the lower bearing.
Just got my powder coating back this arvo and this is what I am up to so far.
Be a while before I can go much further, waiting on chrome bits and it won't be ready for about another 2 weeks and I am going away Sep12 for about 5 weeks.
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
- GT500Andy
- Country: Netherlands
- Suzuki 2-Strokes: T500R, GT500A, TS400, V strom black rhino
Hi Can you let us know how it goes with the KH500 bearings, I'm in the same situation.
Andy
Actually - thinking about it if the sleeve will come off and the resulting stem section is 27 MM then you could use the GT bearing set. I swear I remember the lower triple on the last T500 I pulled apart having the 30MM diameter as part of the lower triple clamp rather than being sleeved but obviously yours is different. You'll have to cut down the sleeve on the top nut or use a nut without the sleeve to use the 25 MM ID upper bearing though.netbikes wrote:BTW the lower shoulder is removable, it is basically a tight fit sleeve, if you apply heat with a flame like oxy or gas gun it will almost fall off.
Jim
Hi Andy, the top nut is at the chromers so won't be able to fully complete the install but I should have some idea if it is going to work without it.GT500Andy wrote:Hi Can you let us know how it goes with the KH500 bearings, I'm in the same situation.
Andy
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
You may find the surface under it a bit rough, the sleeve being as tight as it is may have torn at the surface while being pressed on in the factory, but may not and even if it is it may not make a difference, I'll stop nowdiamondj wrote:Actually - thinking about it if the sleeve will come off and the resulting stem section is 27 MM then you could use the GT bearing set. I swear I remember the lower triple on the last T500 I pulled apart having the 30MM diameter as part of the lower triple clamp rather than being sleeved but obviously yours is different. You'll have to cut down the sleeve on the top nut or use a nut without the sleeve to use the 25 MM ID upper bearing though.netbikes wrote:BTW the lower shoulder is removable, it is basically a tight fit sleeve, if you apply heat with a flame like oxy or gas gun it will almost fall off.
Jim
OR, use another bearing with a slightly larger isd, here we go again
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
- Suzuki 2-Strokes: Suzuki t500 69,71,73, Gt500 76
Jim's right. The Kawa H1/H2 tapered bearings fit the t500 perfectly. I've used them with no trouble, they slot straight in as a replacement.
1969 T500
1973 T500
1971 T500 (being restored)
1976 GT500 (being restored)
2012 Ninja 650
1973 T500
2012 Ninja 650
ordered the bearings today so should know for sure in a couple of days, however the consensus here is that thay will.GT500Andy wrote:Hi Can you let us know how it goes with the KH500 bearings, I'm in the same situation.
Andy
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
hi netbikes ,
A bit late as you just ordered but I bought a taper roller headstock kit from Crooks Suzuki, they fitted straight in.
Cheers Zunspec
Cheers Zunspec
crooks is also about 12 thousands K for me too:-)Zunspec4 wrote:hi netbikes ,
Cheers Zunspec
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
Hi guys, I have updated my project page with the tapered bearing fitting.
http://auction.netbikes.com.au/vjmw.php ... ge=72t500j" onclick="window.open(this.href);return false;
All went pretty well, noted that when fitting the original damper after, very little turning was needed before the neck got over stiff, but thinking I should not need it at all now hey?
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
- dinogt
- Country: France
- Suzuki 2-Strokes: GT 500
the good bearings for GT 500 is SSS250 so 25-48-16 and 27-48-14
blue smoke on the horizon
http://www.dinogt.fr
allballs number is 22-1005 for GT500.
What do you define as "good bearings"?
Cheers....chris
www.netbikes.com.au
www.netbikes.com.au
