4LS work with later gauge?
odbuffalo
Post by odbuffalo »
Hey guys, I have a 4LS front end Im going to put on my 74. Will the 74 GT750 speedo work with the Drum or do I need the speed gauge from the drum bike also?
odbuffalo
Re: 4LS work with later gauge?
Post by odbuffalo »
I guess I can always go aftermarket too.
BRP Tourer
Post by BRP Tourer »
If it is any help, I am running an old set of gauges off a drum brake GT380 on my disc brake GT550 and the speedo is right on accurate.
Buffalo-guy
Post by Buffalo-guy »
The gear ratio on the two speedo drives are the same, so no problem using the later gauge. You will have to use the drum brake cable, for it is specific to that wheel, and will adapt to the later speedo. Should look cool, and work well. Cheers.
Fred
Suzuki GT 750s
Ducati 750 GTs
2007 Duc 1000 GT (the clone)
Suzuki RE5s
odbuffalo
Post by odbuffalo »
Thanks! Im collecting parts, info and putting a plan together. Ill start working on the bike next week.
Thanks for all the great info and help.
