http://www.dinogt.fr/uploads/images/sit ... montee.jpg" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
In few days I will have 1mm alloy gasket to put up the cylinder higher, the alloy gasket need 2 paper gasket.
I alsow have 1.2 and 1.5mm alloy gasket for anyone who have squish cylinder top
The con rod longer give less support of the piston against the cylinder, so less friction and less used and more hp.
The con rod origin angle is 76.39° with the +1.5 mm it do 76.54°.
Any one put a shorter one, by exemple a jet sky one -3mm, the angle is 76.08
