First experience with "dieseling"...scary!
Posted: Sun Jun 20, 2010 5:30 pm
Okay, so I'm playing with the GT380's carbs, trying to figure it out and get it running.
It'll run, but I'm having a hard time setting the idle--more than likely my timing is off, so I'm gonna wait until I get a dial indicator to continue.
The right cylinder is burning the strongest--the pipe is scalding hot to the touch, while the left is pretty hot, but not quite so, and the center pipe is just hot enough to burn skin. Does that make any sense?
I was having overflow in the left cylinder, but I adjusted the float tab and now that isn't a problem.
I have tiny sparks across all points when they're open and fat, blue sparks at the plugs; it seems that my battery is strong.
The bike kicks and starts fairly easily, but it's not running smoothly.
I have the air screws turned out 1.25 turns and have the stock jets in the carbs. I'm running pod filters (screen, not foam).
It's been so long since I've have the carbs completely apart so I don't remember where I have the clips on the needles. Where should I start with them?
Anyway, as I'm fiddling with the idle, I revved it to keep it up as I'm adjusting the knob. Then the engine jumps to 9k rpm. I killed it. Still running. Pull the plug leads. Still running. Shut off the gas. It died after a minute or so. This happened twice.
Before I break or further damage anything, what would you guys recommend I do?
